Hunter Passage 420 Keel Seam question....
May 12, 2022
10
Hunter 420 Charleston
Has anyone seen this before. This is on one side of the keel and a much smaller section on the other side of the keel. It weeped for a couple of days after I had ground it out a little and then appears to have stopped. There is a material between the upper and lower section that has failed.
Any information on what it is and what I should do about it would be very much appreciated. I have read in some other forums that I should ground the entire seam out, maybe 1/4" deep or so, and then 4200/5200, epoxy seal several coats and then thickened epoxy, fair and paint. Thoughts?
Dec 25, 2000
6,071
Something caused the keel stub seal to fail, it appears. Many causes, but normal sailing conditions would not cause this. Our stub seal was leaking due to a rock strike. To do a permanent repair requires that the boat be lifted off the keel, clean and fairing both surfaces, apply 3M5200 to the seal, set the boat back onto the keel, torque all keel bolts, but before, check to make sure the bolt threads have not been stretched. If so, place shims beneath each nut/washer to raise the nut into cleaner threads. Once the 3M5200 has cured, fairing the joint and apply barrier coat and bottom paint. We did this repair in 2004 and remains after thousands of cruising miles.
dmax
Jul 29, 2018
1,362
Telstar 28 Buzzards Bay
Dropping the keel would be the ultimate fix but it's a big job - before that, grind the joint out as deep as you can (1/2 - 3/4") and determine the condition of the remaining factory sealant (probably 5200 or similar). Pour some water into the bilge and see if it weeps out. Determine or have someone determine whether the keel is stable and does not move at all. Examine the keel bolts. If it passes these tests, I would just fill the seam as you've stated and re-torque the bolts. If not...
May 12, 2022
10
Thanks Terry!
Any idea on the torq spec for the bolts? i can imagine a deep well socket, a looong extension and a cheater bar to tighten the bolts, am I close?
10
@dmax, my bilge is for the most part bone dry while in the water. Every once in a while there is some water in the bilge due to various activities like shower sump over flow, or cleaning the bilge and testing the pump, when it rains hard, maybe 1/4" rain water(source still eludes me) collects in the bilge, which after drying, stays dry. So I don't think the water is penetrating the hull/around the bolts. She's been on stilts for a couple of weeks now. I opened up the other, starboard side, grinding a v-groove and now that side is weeping pretty good.
6,071
Thanks Terry!
You're welcome. Different model than the H420, but do not recall the torques settings. This site may have a technician that knows. Yes, pretty much how it's done. It takes a pretty beefy torque wrench to do the job. Yard crew did most of the work. After lifting the boat off of the keel, an FRP guy cleaned and faring the hull stub while the boat remained hanging in the slings. The he did the same to the keel joint. Did not take that long. Then time to lay on a good layer of 3M5200, place the boat back onto the keel, torque the bolts and let it cure overnight.
Next day, re-torque the bolts, faring the joint and prep for barrier coat and three coats of bottom paint (hard blue first coat, ablative black next two). After that ready for splash. This makes for a permanent repair, which I can attest to. Our bilge remains mostly dry, as well. The stuffing box has a a slow drip while underway. Otherwise, no weeping or dripping from the seal when I hauled the boat this past season to redo the bottom, which I do every few years.
Aug 14, 2024
4
Hunter 410 Kingston
I had a similar problem on my 410 which shares the hull and keel with the 420. I've read the keel was originally bedded in epoxy and a crack will form over time naturally as lead and fiberglass are dissimilar materials and expand and contract at different rates. The solution is something that flexes a bit, West System G-Flex was made for this problem, page 55 of the manual covers the repair of hull to keel joints. When I ground out the crack there was no soft sealant.
The torque on the nuts is 325 ft/lbs dry, list of torques from the SBO archive is linked. Attachment is a drawing of the 450 series keel so you know what you are looking at, it's the same layout as our keel. There are 7 1" J bolts and 1 1/2" J bolt aft. I think the purpose of the 1/2" bolt has more to do with stabilizing the liner where the engine is mounted than hold the keel on, or perhaps it was used as a locator during assembly as it is longer than the other J bolts. On my boat the backing plate was not a great fit in this area so I thickened some epoxy and bedded the mount in the epoxy, waited a week and torqued to the nut to 30 ft/lbs, the layup here is hull, liner bonding material, liner so I chose not to try and reach 45 ft/lbs
Keel Bolt Torque Values from the SBO general section
West Systems Manual
6,071
Hi Ian.Thank you for your source on keel bolt torques. I thought ours was around 350, but that was in 2004 when it was done. It would be interesting to know your reading source. When we purchased our 1991 model in 2002, there was no evidence of joint cracking or separation, per the marine survey. That did not happen until the rock strike in 2004. Not to say that what you read is true or otherwise. It just seems odd that the joint just separated to the point of allowing water to seep in without some sort of external force, not just due to dissimilar materials.
Dec 25, 2000
6,071
If it were my boat I would have a marine surveyor assess the keel joint and would follow his recommendations, IMHO.
