- Oct 22, 2014
- 24,925
I was preparing for summer cruising and happened to look at the certification of my propane tanks. Damn,
they were last certified 06/2015. Nearly 11 years. That is probably not good. So off to the Gas Shop with the pair of them. 20 minutes later (and $22 cost), I learned that both were in good condition. Valves function, no signs of rust. The technician also shared that tanks should be certified every 5 years. WOW. This may differ in various states. Might be a good idea to check your tanks.
- The DOT rules state that portable propane tanks must be certified upon manufacture and requalified every 12 years, with subsequent requalifications every 5 to 7 years depending on the method used. Failure to meet these certification timelines renders the tank illegal to refill.
- propane_en_v3.pdf
- Vessel Safety Checks (VSC) by the USCG Auxiliary are voluntary and educational. They check for required safety equipment and "safe galley and heating systems" but do not issue formal citations. If issues are found (e.g., obvious damage, improper installation, or leaks), examiners note them and advise fixes for a decal. They do not enforce tank requalification dates.
- Official USCG boardings or inspections (e.g., for suspected violations or on certain inspected/passenger vessels) focus on whether the system as a whole is safe and compliant with 46 CFR requirements (which reference ABYC A-1 or NFPA 302 for LPG systems). They look at condition, installation, and operation—not the tank's stamped requalification date in isolation. A visibly corroded, damaged, or leaking tank could lead to a deficiency or citation for an unsafe system, regardless of the date. Govinfo
