Thank you for confirmation! That makes sense. Curious why the mix of straight connection vs siphon break. Wonder if a certain year started that?The break was installed by Hunter on my '84 model H-34. Picture attached; you can see it on the back wall. The little check valve on top failed many years ago .. I found an exact replacement and its been fine ever since.
Agree its current configuration is not ideal, part of what prompted this post was to find how other Hunters are setup. Plan to correctly mount the break.The siphon break must be above the waterline and be vertical. It does nothing when lying on its side.
If the engine is above the waterline, then a siphon break isn't necessary. If it is below the waterline it needs a siphon break to prevent water from back filling and flooding the exhaust manifold and cylinders.
Need to validate in person but I do believe so. Very similar to where Kloudie has his mounted.Mine (1985) was exactly the same as Kloudie's. Are there any witness marks on that sound proofing material (compressing or old screw holes)?
The design of a siphon break is not determined by the boat or its builder. It is an independent tool used to prevent the backflow of water when the engine stops. It must be oriented so that he hoses are vertical and the siphon break part is above the two hoses. This is physics, not builder or owner optional.Agree its correct configuration is not ideal,
( I had a typo where I meant to say "theThe design of a siphon break is not determined by the boat or its builder. It is an independent tool used to prevent the backflow of water when the engine stops. It must be oriented so that he hoses are vertical and the siphon break part is above the two hoses. This is physics, not builder or owner optional.
For your own safety and that of your boat, please repair it. From looking at your image, the Previous Owner did not understand the function. Perhaps the attached hoses were too short. I would get longer hoses so that the siphon break can be oriented like the unit, as shown in @kloudie1's image.
Installing a siphon break is fairly low cost. Not having a siphon break when one is needed can lead to a very high cost event. Seems like a simple decision to me.( I had a typo where I meant to say "thecorrectcurrent configuration is not ideal ")
I do understand its role and purpose, my question was regarding the mixed deployment by Hunter. You see Hunter 34's with and without the siphon break (as the exhaust elbow inlet is above the waterline) so was trying to collect a consensus on their deployment.
Current plan is to fix the current siphon break mounting but I am interested in the multiple reports (even by those that have done ocean crossings in their hunters) regarding the removal of the siphon break on their boats
Same with any engine, water comes into the engine cooling through hull and out into the exhaust system and engine block.In a Hunter 34 if there was no anti siphon valve and water was siphoning in:
where would it be coming from?
where would it be going to?
How does it siphon though the raw water pump? Note the question was specifically when siphoning.Same with any engine, water comes into the engine cooling through hull and out into the exhaust system and engine block.
The anti-siphon won’t do anything to prevent that though. When overcranking the water is being actively pushed into the exhaust, and will back up to the lowest point, which is usually the cylinders. That’s different from passively siphoning water up from a source.I think the big benefit it provides for overcranking? If overcrank without starting (no exhaust pressure) with seacock open then could flood the muffler and upto the exhaust elbow
My 1986 Hunter 34 Yanmar 3GM30F has a siphon break between the exhaust elbow (that's being replaced), while looking at other hunter 34 i've not seen a break installed
Wrote a somewhat related article a few years ago about the vacuum break on our boat. Different model, but ... The link to that article below.
ThanksConsider when the engine is shut down after running. The raw water hose will be full and if there is any seepage past the pump impeller, the water would siphon into the muffler and flood the engine. The siphon break stops that..
