Diesel smell in plywood sole-seal with epoxy?
Feb 12, 2022
13
Westerly Fulmar Brudgeport
Due to a slow fuel line leak and a wet bilge, my teak/holly sole smells like diesel. Using fans, Simple Green, Dawn and baking soda, I was able to get the smell out of 5 of the floor sections but the 2 that are closest to the engine still smell strongly. The boards themselves are structurally sound. Would sealing the whole piece in West Systems epoxy encapsulate and get rid of the smell? Any other tips (besides replacement)?
Sep 24, 2018
4,450
Catalina 30 MKIII Chicago
I would highly recommend PureAyre Marine formula. However, I don't know if subjecting the wood to more liquids will have a detrimental effect to it structurally.
Likes: marcham
Feb 12, 2022
13
I took a quick look at the PureAyre website, it looks like it's spray on hard surfaces (fiberglass) and fabric but I didn't see anything about diesel-soaked wood. Do you have any experience with it in this setting? Not sure it would soak into varnished marine plywood. Structurally it seem like the most persistently smelling sections are the most structurally sound
Sep 24, 2018
4,450
I'm not sure about soaking through the varnish but if simple green was able to penetrate, logically this should as well. It will get rid of diesel smell. The owner is very helpful. I suggest calling the number listed on their website
What @dlochner said is spot on. Also, diesel is mostly aliphatic hydrocarbons.... and so is mineral spirits (available at Lowes). In chemistry we say "like disolves like". I suspect that you could use a liberally wetted rag of mineral spirits to get most of the remaining diesel out of the wood. And if that does not get you all the way home, try xylene (also available at Lowes).
Wear a charcoal filtered mask and have good ventilaion. This stuff is hard on your liver and the xylene is a suspect carcinogen.
Apr 8, 2010
2,231
I would suggest removing the obdurate sole sections. Strip the present surface coating. If the wood surface that is revealed still smells contaminated then clean it with "Teaka A and B". We have used this product for decades for stains on solid and veneer teak. Finally, sand as little as possible to preserve the surface veneer, and finish with 5 to 7 coats of varnish. This project will take a few days, but should last for a decade or so.
As an intermediate attempt, mineral spirits (i.e. paint thinner) might do a lot of good to also clean the surface. Sealing the restored surface with varnish would still be my suggestion for the long term.
Sep 24, 2018
4,450
So is diesel BTW!!!
I once spilled kerosene on the back seat of my car. If I understand correctly, kerosene and diesel are chemically similar to one another (at least when it comes to heater fuels). I had to drive all winter with the windows open or I would get a stomach ache. As soon as sprint time came, I was able to leave the windows open overnight. The smell dissipated and a month later it was gone. Fresh air might help reduce the smell of the diesel soaked wood.
Yes that is correct. Both are distilled from crude oil. Kerosene is a lighter molecular weight fraction (lower boiling point) that Diesel. Boiling point roughly tracks molecular weight but chemical structure also affects boiling points. Both are a mixture of many different molecules but the typical number of carbons per kerosene molecule ranges from 9 to 16 carbons where the typical diesel molecule will have a range of 10 - 22 carbons. Diesel is typically made of about 25% aromatic hydrocarbons (the carcinogenic part) where kerosene is slightly less at approximately 15% aromatic.
Jun 25, 2004
589
Hunter 306 Pasadena MD
On the subject of coating plywood with epoxy: I don't have long experience, but I have done quite a bit of it in the past year. My main impression is that it's really much harder to get a good looking surface with epoxy than it is with something like Minwax polycrylic, or some other kind of finish intended for the purpose of ... being a clear finish. Unlike a normal wood finish, epoxy takes hours to set up, so it can be moving slowly for much of that time. It can puddle in different places, like edges, or imperfections in the plywood surface. I'm not saying a decent finish can't be achieved, but it's a real challenge, and this is with clean, dry, new plywood. At the very least, I'd try to get as much of the diesel out of the wood with solvents first, if you want to go this way.
