How to install your floor on your wall.
Nov 6, 2020
573
Mariner 36 California
Our marina has a bin next to the trash bin for reusable stuff.
I have a few wood shops next to our shop. You can regularly find me inside the dumpsters like a homeless Man pulling out their throw aways. I am regularly amazed at the wood they throw away. I just built a kitchenette at work from some giant pieces of clearcoat furniture grade plywood they tossed. The hardwood pieces they toss are amazing. Not very large pieces, but large enough for a hobbyist to use. Unfortunately they dont seem to use teak :(
Likes: Timm R Oday25
PaulK
Dec 1, 2009
1,522
Sabre 402 Southport, CT
Red cedar from the lumberyard, finished with a layer of epoxied fiberglass and three coats of McCloskey Spar Varnish to protect it from UV.
My wife has one too, different design.
dLj
Mar 23, 2017
5,118
That must be a thin layer of glass with that epoxy.... Both kayaks are beautiful!
Maybe it's just me, but I've paddled, rowed, and sailed a number of wooden boats - they seem to have a different "feel" in the way they go through the water compared to any other hull material. Wood just seems to feel better going through the water - I don't know how to explain it...
dj
Those are pretty cool. Its just so hard to throw away all that amazing wood on our boats right?. The teak in some of our older boats is probably from trees that were growing in the 1800's. I wish i had a giant warehouse. I would collect it all haha.
I have a touch of that disease. My shed fills up with bits of this and that... until I no longer own my stuff and my stuff starts to own me... then I do a purge.... and the process starts over again.:facepalm:
Welded from those crappy bed frames they send with a new mattress. The cedar was left over from a friends boat project, so it sort of qualifies.
I made six of these. Four are longer and wider and go across the front of the house, two like this bracket the entry. The top frame lifts off, the boards drop into slots, and there is a plastic liner for the soil. It took quite a few frames, but an inquiry on the neighborhood net got me a whole stack. One day to cut and weld, some more hours cutting cedar boards and finishing everything.
Now that I'm mostly retired, I get some joy out of fabricating stuff from scrap, even when I could just buy the materials. It's fun and feel-good.
LEGIT!!!
That does require more finesse than 2x's. View attachment 236028
The cedar strips were easy to rip from boards, but they were purpose-bought, not leftovers, and building was in the basement.
My daughter and I built a strip plank canoe... it was much easier than I thought it would be.... we also just ripped 2x's. I think she still has that canoe.
dj
Wood flexes differently than most materials. I think that is what you are feeling when you are in a wooden boat. Wood is one of the only known materials that will not work harden over time. So wooden boats can be made in a way that gives and takes with the waves. Other materials need to be stiffened so they will not be destroyed by the constant motion of the waves. The fibers in wood are "bound" to each other through a process called hydrogen bonding... Hydroben bonding can be thought of as being similar to an electrostatic attaction.... so the "bonds" between fibers constantly heal and re-bond after each flex.
I put a red circle around a picture of a single wood fiber.... and the dashed lines between the fibers represent hydrogen bonds.
Nov 6, 2020
573
I have heard that they suspect the one reason the early Vikings were so successful crossing oceans, was that the construction of their boats was made in a way that allowed them to flex considerably without breaking.
Yep... but the European's were also using wood. Part of why the viking longboat was relatively light compared to the European boats was that the Vikings also used lapstrake instead of Carvel construction techniques so they eliminated heavy frames and MASSIVE keels. The overlap created natural "stringers" that gave the boat the longitudinal strength it needed. In the VERY early days of longboat construction they actually stitched the lapstrakes together using horse hair and "plumbed" the gaps with tar. That gave the boats additional flex. After steel bacame more common they "clinked" the strakes together with iron staples. Hence the construction term "clinker". The relatively light nature of the Viking longboat allowed a crew to transport their ships over land.
Likes: BAD ORCA
It did not hurt that they were committed crews that pulled together.
I have never read any stories of mutiny on a Viking Ship. The stories we have are from ones that survived the Darwin challenge of the sea.
Nov 6, 2020
573
lol...good point.
2,485
have come very close to building things in my basement shop that would not fit through the door
When I was a kid my mom wanted a new outside door to the basement. Dad needed a good excuse to do the work so he built a 26 foot Thunderbird there so he had a good excuse to knock the wall out and mom got her new door.
