Lighting upgrades
Sep 24, 2018
4,448
Catalina 30 MKIII Chicago
Like most boats, the lighting in my C30 is less than ideal. Old, power hungry incandescent lamps. I'm interested in upgrading the lighting using standard 12v LED fixtures, LED strips for accent lighting, motion detection (mostly for the head) and possibly some wireless switches (some areas would require significant work to put wiring inside). I'm interested in hearing about what you found to be useful, appealing, awful, etc when you upgraded your lighting.
Likes: Timm R Oday25
May 1, 2011
5,435
Pearson 37 Lusby MD
I changed all my incandescent bulbs and florescent bulbs to LEDs a while back - major difference in electrical consumption. Had to purchase new florescent fixtures and cut wires to make the conversion. Never got into accent lighting.
Jun 14, 2010
2,466
A couple of considerations for you:
1) If your current lights use replaceable bulbs you can probably find compatible LED replacement "bulbs" (LEDs packaged as bulb replacements) in the SBO store or elsewhere online.
2) Motion-sensing lights use current (milliamps) all the time. This parasitic draw may or may not be significant to you, depending on your boats' individual usage and charging, but probably should be considered on an older 30-foot boat.
Jan 4, 2006
7,577
I converted to LED about 15 years ago. The only problem I had at that time was the colour : they varied from urine yellow to the bluest of blues (about 7,000,000,000 K or more) and all claiming to be warm white. The company did keep sending me replacement bulbs until I was satisfied. They would never test them before shipping. AND, they were from a big name supplier who would most likely sue me if I named them today.
Today's world of LED's is light years ahead of 15 years ago but it's something you might want to keep in mind and test them for colour as soon as they arrive. Having said that, remember that 12V LED's are still a very small % of the LED market so quality control in colour may still be open to question.
Sep 24, 2018
4,448
There are plenty of 12v LED lights on the market. The lower end ones simply use a resistor and the higher end ones will have some sort of driver circuit.
There's a HUGE difference in the market between now and 15 years ago. Prices have dropped and overall quality has gone up. I swapped out the incandescent bulbs for automotive ones. They were inexpensive, bright and worked well. There was a slight color shift in one of them after five years but overall I was happy with them.
Any LED product I install will be warm white and will likely have a dimmer
Jan 7, 2011
5,906
Oday 322 East Chicago, IN
I bought some inexpensive LED bulbs to fit my 8 overhead cabin lights. Amazon…$10 for 6 or so I think.
the first ones I bought were too “blue white”, but these warm white ones were perfect.
BlyilyB 6-Pack BA15D 1142 1004 Non-Polarity Warm White LED Bulbs Replacement Lamps DC 12V Interior RV Camper Trailer Lighting Boat Yard Light Tail Bulbs Amazon.com
A few of my cabin lights also have a small red bulb for night vision use (one in the head, one in galley and 1 over the nav desk. They are still incandescent bulbs. Have not felt the need to change them up until now.
No mood lighting on Tally Ho at this point.
Apr 8, 2010
2,231
Over the last two decades we have changed all the bulbs in the OEM fixtures to LED. I also replaced one entire fixture over the galley counter area with a red/white hi/low teak-frame light from Alpenglow. https://www.alpenglowlights.com/
These lights are not cheap, but well engineered and built for a lifetime of use, and I recommend their lights highly.
Jul 7, 2004
8,525
Hunter 30T Cheney, KS
I used MarineBeam for all my lighting inside and out. Staff was helpful too! They make some cool below deck bulbs that toggle from red>white>off. You save your night vision.
Likes: SycloneDriver
Sep 24, 2018
4,448
To try to steer the conversation...
What did you like and dislike about your lighting upgrade?
What would you do differently?
Were there any lessons learned?
Johnb
Hunter 37-cutter Richmond CA
What I like:
1 The light is really good. You should become familiar with the following
Lumens - the amount of light that the lamp puts out - 1500 will light the whole main cabin for reading, cooking or other tasks that include detail. For a focused reading light 300 or more will do it.
Color temperature - 2700 is nice and warm but for detailed tasks or reading 3500 may suit you better.
CRI - color rendering index - a measure of how well the light shows a range of colors - less than 80 is unacceptable to me, 85 is better and 90 is better than I need.
2 The much lower current draw means we don't have to be stingy with the light.
I got some fancy fittings with touch on and off that gave a lot of trouble turning on and off by themselves or not responding to touch. I hacked into them and installed a mechanical on off switch and they have now been trouble free for 6 years.
Some earlier cheap ones were electrically noisy but I have had no problems in that regard.
I have been lucky that the wiring in my boat is still in good condition and I could just use it. In some places I installed complete new fittings and in others just new bulbs. It all works so well that we don't use any AC lighting, even at the dock, we just run off battery and solar.
My running, steaming and deck lights are also all LED.
I recently took a cruise on a power yacht. The cabin lighting was indirect. That is the light emanated from trim features about halfway up the cabin partition and the light was continuous on the two sides of the cabin. The light reflected off the light color of the ceiling liner. I thought it was very pleasant and comforting to the eye. Almost like natural light. There were no bright spots to harsh the eye. There were also focused lights strategically located at spots for reading or focused activity. If I were to redo cabin lighting I would try to achieve that.
Sep 24, 2018
4,448
I'm very familiar with lumens, CRI and color temperature but these numbers provide a good reference point for this application, especially the lumens. I do want a warm light and agree that it should be no colder than 3500K.
For winter work, I was running a bunch of household LED lights. It was OK but lots of messy cabling and spotty lighting. This year I bought a 4ft 5500 lumen shop light from Harbor Freight. It was a total game changer. It lights up the whole cabin and I only need a secondary light for cabinets and compartments.
Now this would be the ideal setup. Lighting can truly transform a space but it takes time to get it right. Some of the newer, high end yachts have lots of pretty lighting and it is impressive. It's also a lot cheaper than fancy woodwork.
dLj
Mar 23, 2017
5,026
This is a good thread. I've been thinking about my lighting. I did change most of my interior lights to have LED replacement bulbs. I have a few left to do that I rarely use.
I've found it to be quite difficult to get the right light intensity. I'm not sure if that's the right term. Basically the quantity or amount of light for a given space. There is a significant difference between the amount of light I want when I'm docked compared to when I'm on passage. I've had to change bulbs a couple times trying to get the perfect balance.
I was gifted three sets of "fairy lights". These are battery operated LED strings - for anyone that is not familiar with them. It's amazing how well they work. Clearly I'll be looking at LED string lights.
I've been on high end boats with the touch controls - I'm not a fan. I've found them essentially unreliable.
I'm not sure I'm a fan of all the modern electronic controls. They haven't been around long enough for there to exist a long enough time frame to really understand long term reliability.
dj
Sep 24, 2018
4,448
dj
I'm planning on putting in a master dimmer for the cabin lights. It can be installed before or after a relay/switch going to the lights. There are many out there that are more elegant than the example below
Alternatively, you can use some sort of lighting filter inside a fixture to dim the output. Some can alter the color or perceived temperature while reducing output. Straight grays or window tinting can dim the output without altering anything else. Frosted gels or possibly frosted contact paper for windows can create more even lighting while making it easier on the eyes when looking directly at the light. Frosted filters will reduce output a little bit. Every time light passes through something, the output will be reduced due to impurities in the medium or reflections back towards the light source.
I'm also a fan of light strings and similar multi LED sources of light. I installed some LED tape in an engine bay once. It was wonderful. The unexpected advantage of them was there were virtually no shadows. I installed barrel adapters on the end for power which allowed me to plug them into a 120v adapter in the winter. Hopefully the boat's new owner appreciates it
Likes: JBP-PA
JBP-PA
Apr 29, 2022
782
Jeanneau Tonic 23 Erie, PA
In my head, for at night use, I like a very dim indirect light that isn't blinding. These little stick on lights are perfect. I stick one under the counter where I can reach it. Since it's only used for a minute each night, the battery lasts years (unless you forget to turn it off).
JBP-PA
Apr 29, 2022
782
I added some LED strips under my table on a dimmer. I like them for ambient light. I used some leftover strips from a house project, and they tend to flicker on the highest setting. I am not sure why but I suspect they need steady 12V, not the 13+Volts on the boat. I'd like to add more under the galley toe kick.
Likes: shemandr
JBP-PA
Apr 29, 2022
782
For my cabin lights, I tried LED bulbs, but they weren't very bright. I don't have a lot of standing room and I'd occasionally hit my head on the old fixtures. I switched to these low profile lights. The first ones I bought were defective but the manufacturer replaced them with no hassle.
They have full brightness warm white, red mode, and a nightlight mode which is occasionally useful.
Johnb
I checked out the website and also the specifications on these lamps and to be honest at $36 for 390 lumens I feel they are a bit shy on bang for the buck compared with what is available now. A power consumption of 390/6=65 lumens per watt is also on the low end.
JBP-PA
Apr 29, 2022
782
I don't remember what I paid, but it was pre-tariff. I also needed low profile.
