Deviation from Standard Installation of Wet Exhaust
Jan 9, 2025
51
Catalina 30' Tall Rig John Wayne Marina, Sequim, WA
1977 Catalina 30', Atomic 4 engine: I'm replacing the engine, so I have the stove and kitchen bar removed currently. I'm also replacing the Aqua Lift Muffler and why not replace the exhaust hose, right? So, I was evaluating the exhaust hose replacement project and come to find out my exhaust hose is 100% "inside" the cabin space. No part of it enters the port side lazarette. At the ice box it turns 90 degrees and parallels the gas tank heading to the transom. Also, the one-way check valve is not there.
Q: Should I install the new hose according to Catalina production schematic run? I'm thinking it would be beneficial to do so to better prevent inflow of seawater during following seas or a port tac.
Jan 4, 2006
7,650
Does the original Cat installation employ an internal loop which rises as high as possible to avoid seawater backflow as opposed to using a check valve. The internal loop is the most common method I've seen of avoiding backflow.
Jan 9, 2025
51
No it does not. the production route comes out of the aqua lift muffler rises about 18 inches, goes behind the stove and ice box up another 6 inches and out into the port lazarette where a one-way valve would be installed. These one-way valves were prone to failure, and at the point where this would be is directly under the lid of the port side lazarette, pretty high off the water. At this point the route dives back down to the aft bulkhead at the waterline and through it to the transom through hull
51
I've been reviewing photos of other members exhaust hose replacement jobs, and I have a question:
It appears some 30' boats (talking about Catalina 30's only) hoses run "over the top" of the aft bulkhead of the port lazarette and others run through this aft bulkhead at the bottom. So far it's my opinion that the higher the better, especially if there's to be no loop or one-way check valve.
Jan 4, 2006
7,650
Don't know what those Cat guys were smoking when they came up with that exhaust system :
................ but in order to have backflow due to a following wave, you would need a wave higher than your lazarette = H. A check valve any where in an exhaust hose is not recommended because the corrosive exhaust gasses would eventually corrode out the flapper or the flapper would plug with carbon.
If the exhaust hose lays on the bottom of the hull as mine does, then you need an exhaust loop. In my H-310, the exhaust hose lays on the bottom of the hull from the engine exhaust all the way back to where the bottom of the transom meets the bottom of the hull :
When it reaches the bottom of the transom, it rises up in a tight loop to the height of the transom and then down to the bottom of the hull where it discharges underwater.
Backflow is only possible if a following wave rises to the top of the transom with the engine shut down. At that point, one would have far greater problems than backflowing water in the exhaust hose :yikes:.
My boat came with an exhaust pipe that rises 24” from the engine exhaust manifold does a 180 drops about 15” at which point the raw heated water from the engine is injected and runs at a shallow angle out through the stern tube. There is a rubber flapper on the stern tube. When up it lets exhaust and water exit. When down it lessens the possibility of water to flow up the exhaust system
Arrow points to exhaust stern tube sitting well above the water line.
Jan 9, 2025
51
I've also installed a through hull with a gate.
I guess from all the comments I could be overthinking the issue. There's no reason I should have to install according to Catalina but rather add a loop or run the new hose as high up under the deck before descending to the transom. Thanks for all the effort and pictures guys.
51
Finally finished pulling in 25' of new exhaust hose and everything everybody said was true. Hell of a job. Had to use a chain fall to inch it in. But ran the length to the transom as depicted in the OEM manual above.
WOW... 25ft on a 30ft boat. Amazing.
I installed a new hose after my engine rebuild. It is not an easy task. Getting it into place. And I was dealing with about 11ft of hose. Then, cutting it in place for the final fit.
Likes: Night Watch
Jan 9, 2025
51
I had about 2' left over, but if you take a look at the OEM route, you'll see why it was so long.
Yes. I did. On mine, it is a straight shot from the exhaust elbow to the stern. All boats are a bit different.
Congrats.:cool:
Jan 9, 2025
51
On another note: Once you told me Everett Marina could demast a boat while alongside the breakwater. I'm interested in replacing my mast base and masthead this summer w/o pulling the boat out of the water. Seems the way to go, but I need to ascertain if Port Angeles or Port Townsend can also provide the same service. I don't think Port Townsend can but not sure about Port Angeles yet.
Where you are located PA or PT would be the easiest. Depends on the length of their crane lift and the height of the dock at the haul out. Everett has the ideal setup for the task. That would be a long distance for you to drive and accomplish the repair.
With all the talent at Boat Haven, I would sure check it out.
I had a great stay at John Wayne Marina last spring. Met up with some of my cousins. Great meal at the Marina. You have a special slice of heaven on the Juan D'Fuca.
Likes: Night Watch
