TV Options
Aug 26, 2007
282
Hunter 41DS Ventura, California
My marina no longer allows antennas/ hardware to be mounted on the dock/ slips. I have been trying to find an antenna that I can use in the cabin or rail mount. I have tried several models but reception has been marginal to unacceptable so far.
Anybody had success with either an inside or an external one that can be mounted (or be removed ) to not interfere while sailing? We don't spend enough time on the boat to merit streaming with satellite (Skylink)
May 1, 2011
5,306
Pearson 37 Lusby MD
Have you contemplated an antenna you could hoist on a halyard while in the slip? Sorry, no specific models off the top of my head. :beer:
I opted for tv and streaming via my Cell phone or Starlink. Both have proven excellent for my usage.
Assuming you are in Ventura Harbor your are about 60 mile indirect sight of Mt Wilson where LA locates there TV Transmission antennae’s. Your experience so far may be a result of the antenna not being rated for the distance.
Here are a couple of options you might explore.
  • Majestic UFO X: rated @ 60 mile High-gain (30 dB) dome for fringe signals;
  • 1byone Amplified Marine: rated at 50 miles plus. Affordable flat-mount with 360° horizontal reception; low-profile for sailboats;
I have no experience with either of them. There specifications appear to be in line with your assumed needs.
Good Luck
Feb 10, 2004
4,190
Hunter 40.5 Warwick, RI
I have a Majestic UFO X antenna about 52' off the water on my mast. It does a good job for stations that are 15-40 miles away. The distance is over both land and water.
But I primarily use mobile data or my marina's wifi to stream TV. I have a hot spot with unlimited 5G data that I use when I'm away from my marina. It's a solid solution except for the rare times that I'm too far from a cell tower.
282
Thanks to all who posted. My marina doesn't have WIFI (coming they say :laugh:) and my TV is dumb so streaming is not an option. The ones I have tried have been powered so getting power to the antenna limits placement. I will check out your suggested antennas. Thanks again!
184
Catalina 34 Herring Bay Chesapeake, MD
Any of the Roku units ($40-100) will turn your TV smart for any streaming. Sorry I cannot suggest an external antenna. Good luck
That would be my recommendation too. Some of the Roku sticks are cheaper than that even. You can use a cell phone as a hotspot for the Roku to connect to.
Feb 10, 2004
4,190
The Majestic and others are all powered, but the power required is small - their spec claims 100mA. The power flows up the antenna cable, so installation is very easy. You could hoist the antenna when needed, perhaps from a spreader so that it doesn't bang on the mast.
My TV is dumb as well, and I use a $30 Roku device. The TV does have a HDMI input which is required by the Roku device that I have.
Jan 7, 2011
5,882
Oday 322 East Chicago, IN
On my weekend sail last year, I used a Firestick on my old dumb LCD TV on Tally Ho to stream TV using my phone as the hot spot. It worked OK but the stream was not great. I had an old antenna in a locker (UFO looking plastic housing) and some coax cable. So I stuck the antenna up in the sail bag, ran the cable through the main hatch and plugged it into the TV… I had like 60 channels of digital TV from that little antenna. I will say I was anchored about 30 miles from downtown Chicago and could see the skyline across the water.
This video has some footage of the set up I used around the 30:00 minute mark.
