that's like saying you shouldn't watch TV if you need to use a remote control (putting aside that you can't buy one without a remote anymore)
Should you not sail if you need to wear glasses to see? I don't think strength counts as much for crew safety as having agility
Glasses ? TV remotes ? Not even close to a fair comparison. Neither of those creates increased unnecessary risk. Glasses reduces it.
The elderly require retesting for driver licences due to risk of cognitive decline. They tend to give up activities that require agility and strength. All of which are required to run a sailboat.
For those that are younger, relying on increasingly complex gear so you can sail a recreational boat is against the KISS principle. If you can't handle using the powered winches manually if they fail at an inopportune moment (which is when gear fails), you should get a smaller boat, or better winches.
IMO it's better to simply avoid the powered winches all together. A manual winch is never going to drag your whole body into it on its own. It has less points of failure.
Of course this doesn't apply to race boats, and huge boats that require powered winches regardless of crew size/ability.
This guy was in his mid 70s, sailing a big boat that required him to have powered winches, and acquire extra crew (some of which had only been on the boat for a short time, and were of unstated skill).
Apparently he didn't maintain the winches, which is possibly due to cost. Similar to why old wire winches are likely kept in service, in spite of their problems.
Had he been sailing a boat of reasonable size, with its higher safety factor due to decreased maintenance cost, lower rig loads, crew size, etc. he'd be alive today.
Same applies to the couple with the big yacht that died a year ago when the boat gybed. Boat too big. Need to rely on itinerent, and likely in experienced crew. Couple both dead.
You do realize that drink holders can hold all sorts of drinks? Even non-alcoholic ones? Even plain water?
I read that post as two different things.. the first sentence joking about booze, and the second sentence about drink holder placement, regardless of beverage ?
But using the same logic, one would not have a boat with a boom or any loaded blocks, since accidents and deaths by those devices far outnumber those by electric winches.
Not a fair comparison. Almost every sailboat has a boom and loaded blocks, which is why they are the cause of more accidents.
Powered winches increase risk. Sometimes needlessly. If that can be avoided why not do so ?
All said, It would be interesting to see stats on powered winch incidents.
Stories like this one are sensational so people hear about them. The public don't often hear about people with lesser injuries.
