I have a 15 foot Spindrift with centerboard. Will use mostly in saltwater bays for light cruising. What are your thoughts on electric outboards? Any recommendations is appreciated
Mostly power. An electric trolling motor is designed to sit on the bow of a Bass Boat and move the boat around a fairly small fishing hole. An electric outboard is designed to power a boat in the same manner as a small gas outboard of 2-4 HP. The electric outboards tend to be self-contained, i.e, the battery is proprietary and is integral with the propulsion unit (shaft, motor, and prop). Trolling motors have separate batteries stored on the boat. An electric outboard typically comes with its own charger, while a trolling motor will need a charger suitable for the battery chemistry being used.Thank you. But what is the difference between a electric trolling motor and electric outboard motor?
Dave mentioned power - but that's really a gray area because the smallest "outboards" actually have less power than the largest "trolling motors." His Torqueedo gets him 4kt vs my 3 kt - but my motor is ~1/2 the power.Thank you. But what is the difference between a electric trolling motor and electric outboard motor?
Mathematically, you can't make an accurate comparison. But your boat doesn't care what the math says. In actual trials on my Mariner, I got a top speed of 5.5kts. Hull speed (with a big wake and a squatting transom) is 5.7kts, achievable with the typical 5-6hp gas outboards. Others with Mariners use the 2 and 2.5hp outboards, and don't worry about achieving hull speed. So I find the 3hp equivalent to be accurate for the Epropulsion Spirit.You cannot convert Pound of Thrust figures to Horsepower. The components of the mathematical formulas are not relatable. At best you have a subjective comparison of performance as rated by the manufacturer.
Not a Dewalt but here you goI keep wondering when Dewalt is going to put one out
Does it really matter? Both trolling motors and electric outboard motors have been used as auxiliary motors on sailboats. Auxiliary motors on sailboats can be big enough to take them to hull speed against the wind and waves (anything more is a waste), or small and just powerful enough to get a sailboat away from the dock or launching ramp. What you want depends on how you feel about motoring on your sailboat, and the circumstances under which you would use an auxiliary motor. Manufacturers seem to have little problem with classifying their electric offerings as one or the other, although the overlap of the bigger trolling motors and the smaller electric outboards is growing. The smaller electric outboards generally have an attached battery, trolling motors do not.Thank you. But what is the difference between a electric trolling motor and electric outboard motor?
Depends upon whether you're speaking fisherman or pirate. Because sailors need an auxiliary language.
*groan*Thank you. But what is the difference between a electric trolling motor and electric outboard motor?
Based on this, I would recommend a trolling motor. 36lbs would be my recommendation. Battery size depends on how much motoring you plan on doing. I used 10A gel cells to get to my mooring as they were small but I could get a few short trips out of themThank you for take the time to review and reply to my post. I am relatively new to sailing I will sail in a large lake as well as Great South Bay and other inlet. I will always have shore lines in sight and sail in mild wind conditions
Same thing as when you run out of gas, or more likely, the gas outboard won't start.Just remember what happens when your battery dies!
That's me in the dinghy rescuing a friend. LOL
Electric outboards with integral batteries generally have instruments that display remaining battery capacity and distance/time left at the current throttle setting.Just remember what happens when your battery dies!
