looking to add goal post to my tandem axle trailer for my 97 Mac26X.
Nov 2, 2025
5
Macgregor 26X Belton
looking to add either on set behind the back of fenders and possibly another set in front of the fenders. I believe this will prevent/reduce the weathervane from winds along with helping stay off the fenders.
pgandw
Oct 14, 2023
195
Stuart (ODay) Mariner 19 Yeopim Creek
Not a McGregor, but an ODay Mariner (19ft). Have added goal posts to the rear of my trailer to help the line up when winching her home. However, the stern of a Mariner is a fair amount narrower than the maximum beam. Of course, the max beam is what the posts must be set to. Nevertheless, the max leverage for the goal posts is at the rear of the trailer, AND the max beam tends to be pretty close to the rear when line up is most critical.
The winch should be centering the bow during retrieval, so I'm not sure how effective mid-trailer goal posts would be. I would start with rear pair, and see if you still need mid-trailer pair.
Haven't launched or retrieved with the goal posts yet, but every Mariner owner who has goal posts swears by them. Without the goal posts, I've sworn at not getting correct line up during retrieval.
I know goal posts are essential for my boat lifts, and since there is no winch to center the bow, I have them fore and aft. On my 19ft powerboat, the goal posts also provide fore and aft reference before I lift the boat. Line up the gas tank filler with the forward goal post, and I'm in the right position every time.
Fred W
Stuart (ODay) Mariner #4133 Sweet P
Likes: Rs97Mac26X
Nov 2, 2025
5
Fred W
Thanks for the reply and the information!
Sep 24, 2018
3,879
Catalina 30 MKIII Chicago
No, I sold the boat. I made it out of Unistrut for the base, a couple of pipe flanges and nipples and PVC for the sides. The cost was nearly the same as pre made ones by the time I was done. The unistrut would twist in the wind so I had to tie it off to the stanchions. The heavy dipped galvanized trailer didnt take well to welding so I had to use beam clamps to mount it. Buying a premade one is the way to go in this case
Likes: Rs97Mac26X
