I was looking for an anchor alarm app. There are many choices out there. I'm curious which ones people like? Is there e one or two that are better / more cost effective than others? What are your thoughts?
I also like Aqua Maps as my primary nav app. I prefer it overall to Navionics, although they both have unique features.Thank you for the responses. I was looking for a backup to my anchor alarm on my B&G MFD not a primary source but I really appreciate the input. @Captain Larry-DH thank you for the Aqua Map suggestion I will look into that. @marcham thank you for the signal k suggestion. That looks pretty interesting. Sounds like a fun winter project for me. Or maybe even a dedicated board like @Foswick did.
Aqua Maps has all of those features, and more.My favorite isn't available anymore, the developer seems to have disappeared. It was called "My Anchor Watch" by SjaellSoft. The features I liked were
Ability to set anchor position after you are anchored just by entering bearing and range to anchor. If you guess wrong, it was easy to adjust.
Easy ability to adjust warning and alarm zones and swing angles.
Easy ability to compensate for GPS accuracy, update frequency, loss of GPS alarm, etc.
Great drift log that showed my track all night.
Very reliable, I never had it fail once.
Still looking for another one.
Where is the swing angle? I couldn't find where to set that.Aqua Maps has all of those features, and more.
Start using the anchor alarm function, then to set anchor position choose either live anchoring or after drop. You can then set (and edit) position, bearing, and distance. (No GPS position in the attached screen grab). No swing angle limit - you are setting a radius from the anchor position. If you‘re concerned about wind shifts you can set the anchor distance to be closer than it is, and swinging out of that circle will set off your alarm.Where is the swing angle? I couldn't find where to set that.
Ah , well. Maybe they will add that feature soon. I almost always use it. None the less, I'll give it a try.Start using the anchor alarm function, then to set anchor position choose either live anchoring or after drop. You can then set (and edit) position, bearing, and distance. (No GPS position in the attached screen grab). No swing angle limit - you are setting a radius from the anchor position. If you‘re concerned about wind shifts you can set the anchor distance to be closer than it is, and swinging out of that circle will set off your alarm.
Thank you for the link!This guy has a spreadsheet comparing features, but it is a few years old now.
Anchor Alarm Apps - Which one is best for you? A comprehensive Overview
A comprehensive overview of 50+ anchor alarm apps for iOS and Android, with a detailed feature comparison chart to allow you to pick the best anchor app for your anchor watch.trimaran-san.de
The anchor scope calculator by the same author has become my best buddy for making sure I have anough scope out.This guy has a spreadsheet comparing features, but it is a few years old now.
