You can't upgrade your vent to 1" by just replacing the thru-hull.  To do that  requires either a new 1" vent fitting on the tank or an adapter in the current 5/8"  line to upsize the vent line to 1".  Thru-hull would no longer be a "vent" thru-hull because they're only available in 5/8". Instead you'd need a 1"  open bulkhead (aka "mushroom") fitting--the same kind your bilge pumps use.  It needs to be either metal (Perko has stainless steel or chrome plated).This provides two advantages:  allow the tank to breathe--which is the key to preventing odor out the vent--and also prevent vent blockages by allowing you to put a hose nozzle against it on a regular basis to back flush the vent line. Anything trying to set up housekeeping in it will get a water slide ride into the tank.
What part are you trying to identify?
--Peggie
Hello Peggie,
Hope your day is going well.
Loved your book, helped me re-do my plumbing and for my boat to no longer stink.
I have a new IMTRA Nauta 35.5.
It has a vent for the holding tank.
The vent is 5/8"s
The vent goes up the hose to a Barb to NPT 1/2"
the barb2NPT goes into a 1/2" knee
The knee attaches to the thruhull.
The thru-hull is what broke.
It is plastic and sun degraded it.
The "Diameter" of the mushroom on the outside of the boat is 1"
The pipe itself is 1/2" inch
the length is 2" inches.
I don't seem able to find any mushroom thru-hull that is 1" in diameter.
They all seem to be 1.5 inch or more.
So that is my issue, finding a thru-hull.
In the meantime I have ordered a regular one I could find which is 1.5" and will dremel it to make it fit
but obv won't be pretty.
Unrelated, any recommendation between the plastic and the metal ones ?
