Rudder packing gland
bob45
Nov 14, 2023
48
islander 34-2 lake michigan
Does anyone know what kind of of packing gland this is? (I know it’s not the best pic). It’s on an Islander 34-2 1985. I need to drop the rudder and was thinking of replacing while its out (at the very least I don’t want mess it up)
971
It looks to be the same type used on the early Hunters. It operates the same way as the cutlass bearing on the prop shaft works, except it uses three bolts to tighten and compress the wax gland. If you need to service the gland, remove the bolts and slide the bronze ring up the rudder shaft.
bob45
Nov 14, 2023
48
if that’s the case, can I drop the rudder without messing with it?
Apr 22, 2011
971
It should not interfere with the shaft while dropping the rudder. Wouldn't hurt to loosen the bolts though.
Sep 17, 2012
115
Morgan 383 Fairhaven, NY
It would be a false economy to not replace the packing and clamps while the rudder is out. Its 40 years old. Look at it! It needs to come out, be cleaned and rebuilt. Put a few people in the cockpit, it can go underwater and leak. Put it in vinegar for a few days, it'll shine up. West Marine will have packing and real SS hose clamps.
Apr 8, 2010
2,231
while the rudder is out try to pump some (way overdue?) grease into that factory 'zerk'. Hope it works, and... then pump in a lot while turning the shaft back-n-forth once back in the water.
bob45
Nov 14, 2023
48
Do I need to clean out the old stuff?
Sep 17, 2012
115
There are usually 2-4 packing rings in there. Pull them out, clean area, put new rings in - staggering the ends so any small gaps don't line up.
You won't have to do it again for 20-30 years!
bob45
Nov 14, 2023
48
So that whole assembly (top and bottom) came off shaft tube once I loosened the hose clamp. Should the bottom half be affixed to the boat better? It looks like there may have been some 4200 or something at some point.
2,231
I am pretty sure that, like the very-similar one on our rudder post, the builder glued it to the FRP tube. Usually with poly putty, but could have been sealant. Our was loosened when we bought our boat used and it was epoxed back into place. One you clean up the tube and post and the rest of that "out of sight and out of mind" part of your boat this work will be easier to plan and execute.
(All part of the joys of buying someone else's 'deferred maintenance ' )
