Statue of limitations on DPO ?
Mar 2, 2019
679
Oday 25 Milwaukee
We've owned our 25 Oday 20 years by now . Perhaps a bit petty of me , I've driven myself close to the edge of sanity in my attempt at a dry bilge .
I've resealed the traveller that runs across the bridge deck . I've resealed the cockpit cubby's where the lines for the dare stay are stashed . Checked rechecked the port lights for any signs of leaking .
This fall , I decided to remove the bulkhead mounted sailing gauges that have never worked . A friend's son made me some plugs with his 3 D printer that were a perfect fit . When I pulled out the first gauge I was stunned to see there was nothing holding it in place other than gravity ! It never occurred to me that the leaks were from the factory installation of an accessory!
Those sneaky yacht builders. Always looking for a shortcut. :banghead:
  • Ha
Likes: Timm R Oday25
dLj
Mar 23, 2017
5,255
I don't think there is anything "petty" about wanting and working towards having a dry boat. I hate a wet boat. Having a dry boat is the best!
dj
Likes: Indysailor
Oct 10, 2009
1,118
Beneteau 393 Muskegon
It's been multiple decades, how do you know the gauges were factory installed? Also, I never found any silicone bedding on my ODay 23 and in fact when I pulled one of the winches, I found butyl tape. Everything else was bedded with some type of marine caulk.
I found butyl on the windows but everything else was either silicone or no sealant at all
In a previous life, I restored a MacGregor 22. The ports were bedded with plumber's putty. And it worked for 30 years so... I did the same. The ports never leaked. :cool:
WayneH
Tartan 37 287 Pensacola, FL
The hull to deck joint on my 1980 Tartan is the original non-leaking butyl. So guess what I used to rebed ports and stanchions during her retrofit?
Here is another…
I think co-pilot did a better job.
