Have a boomaroo 22 Australia (Catalina) and the swing keel pivot hole is completely rusted. There seems to be 2 options.
1- reweld the cast iron into a solid piece and drill a 1inch hole for the pivot pin,
2- cut out the hole and insert a new piece of metal that is bolted into the keel.
3- make a sort of sleeve that fits directly over the pivot hole but larger , maybe 150cm which gets screwed into the keel.
Comments pls.
Comments pls.
