Beneteau Oceanis 46 2007 - lines
Oct 18, 2025
7
Beneteau Oceanis 46 Berlin
Hello,
could anyone help me with the lines.
My boat has a Selden 304S Furler and in mast main sheet
How long are the lines and what are the diameter?
I will change the running rigging.
Lines head sail (Genoa)
Halyard
Sheet
Roller Furling Line
Lines Main sail (in-mast furling)
Halyard
Furling
Outhaul
Sheet
Important for me is the length
Regards Norman
You may find a manual for your boat under the Owners Resources tab on the homepage. It may require you to register - I'm not sure.
The owners manual for my 356 has those specifications. I would add mine specified older cordage which is not necessarily what you would use today. While it can be a lot work I think it's best to look at the physical properties of the cordage and match it to the anticipated loads, abrasion resistance, uv resistance, stiffness, holding in stoppers and terminal cleats, hand (Feel), and price.
You can find the cordage specifications by visiting the websites for Sampson, New England Ropes, and a few other companies. You'll want to filter by what is available locally since shipping could get very expensive.
Good luck!
Oct 18, 2025
7
Hello Andrew,
I have the owner's book, but there is no information about the lenghts.
Thank you for your request
Nice Sunday
Jun 21, 2004
3,050
Beneteau 343 Slidell, LA
Unusual. In my owner’s manual there is one page in the “rigging” section that lists the diameter, length, & manufacturer of each line organized by function.
Jun 21, 2004
3,050
Norman,
Perhaps you can call your nearest Beneteau dealer or the Beneteau factory and ask them to provide the running rigging spec sheet for the various lines For your specific year & model.
Oct 18, 2025
7
Hello, in the past, I asked the Beneteau factory, but they can not help. I try a dealer
Thank you
Jun 21, 2004
3,050
Last resort is to measure your lines directly on your boat. Make a chart of all the lines and keep a copy onboard and on a computer file because you will need it in the future. Also check the manuals for your furlers as there should be recommended line diameters for your furler model.
7
Thank you. I am not at the boat. that's my problem. I asked a dealer, he can not help.
