Replacing starboard rope clutch
Apr 6, 2013
166
Catalina 310 Annapolis
The clutch for my main halyard refuses to stay in the open position which makes it difficult to drop the sail when single -handing. As a temporary solution, I swapped it into the clutch and block for the Spinnaker halyard. I think I can find a quad clutch online and would like to replace it when on the hard. I understand that the OEM clutch is screwed into a threaded plate glassed into the deck. I understand, further, it can be difficult to remove the original clutch without stripping the threads in the plate. Has anyone replaced their starboard clutch and, if so, what are some pointers to do it successfully? Also, any advice on what model replacement clutch to get? Catalina Direct doesn't seem to carry a quad clutch. I want see if I can match up the mounting holes. Thanks!
Mar 6, 2008
1,531
As above, I would try and fix the problem first. And if replacing is the only solution then I would rather have separate ones so that if one breakes you do not have to replace all four.
If you decide to replace one and the holes do not match, you can caulk one hole and drill a new one.
JRacer
Aug 9, 2011
1,409
Perhaps send a picture to Garhauer and ask their tech support if in fact it is their product and ask for advice?
And, I wouldn't "caulk" a hole in the deck. I would over-drill it and fill it with epoxy.
Apr 10, 2010
158
Catalina 310 166 Dartmouth, Nova Scotia
Had the same problem with my clutches and found forward pivot point screws to be very loose as described by Calif.Ted. tightened them after I applied thread lock and no problems. Also you can get a rebuilt kit for these clutches should the need arise.
Likes: Alansails
Aug 29, 2016
138
Catalina 2004 310 (Hull #250) BC
I had the exact problem recently - clutch would not stay open. I asked a pro rigger and he confirmed: Garhauer clutch. and yes, tightening the screw slightly to increase friction on the spring totally fixed the problem, as mentioned by other posters. Easy.
Likes: Alansails
