ENO Oven/3 burner stove 1991 - Model 0439-85 - Beneteau First 310
OWI
Apr 17, 2020
16
Beneteau First 310 Milwaukee
Our stove is an ENO Table Cooker 0439-85 (1991). It has served us very well over the years, but we have a problem with the oven in that i takes a very long time to heat up. The heating element seems to always burn at a "low" or minimum setting, no matter what the position of the knob is.
We do not have that problem with any of the other knobs of the stove. You can turn them from Low to High at any interval. It is also possible to turn on multiple burners at the same time. Hence gas flow to the unit does not seem to be the problem.
We reached out the Eno France a month ago but have yet to hear back from them.
Does anybody have the same ENO oven and has a clue as to what may be the problem?
We also need to replace the handle bar of the oven door, so I am also looking for a reponsive source in the US that can help.
Thanks!
Oscar
2,257
Eno is a pretty well known supplier of OEM parts. I wonder if Beneteau could point you in the right direction.
Fisheries web page tells us all to shop them for parts. (!)
OWI
Apr 17, 2020
16
Thanks for pointing to the US source. Will contact them tomorrow and see if they can help with replacing the broken oven door handle.
Still looking for clues on improving the functionality of the oven...
Oct 3, 2025
1
Beneteau Oceanis 430 Duluth
We have the same one with the same problem. Did you ever resolve the issue? I am also looking for pot holder arms. Do you use them & do they need to be for this specific model? I cannot seem to find anything online.
Thank you kindly!
May 12, 2025
107
Macgregor 22 Silverton OR
My electric oven unlike the stove top burners has temperature settings from zero to bake in degrees instead of low to high which makes sense since it is not a furnace. I kind of expect similar engineering for a properly constructed boat oven. Was it built before Y2K? somebody may have reset the timer wrong.
