I had to cut away a chunk of floor to get access to the forward part of the bilge/keel bolt in recent phase of refit. Now that thats complete, i'm working on some minor repairs under the shower pan and adding in some structural supports to the floor under the cutout. This cutout will become an access floor board that can be lifted up. I finished the structural repairs yesterday (no pic) and am making a floor board this week out of 3/4 marine ply to fit in the opening.
Unfortunately, I cant find teak and holly plywood that has the same width strips that match my floor, so my idea is to laminate 1/4" thickness teak and holly on top of this 3/4" floorboard im making, so that it matches the floor on either side of the cutout. Is there a very particular type of holly board that I should be looking for, for this application? I'm finding boards that are long enough, but have a greyish smudges and grain that seems to run diagonal. I will need to saw it into very clean and precise 1/8" width pieces, so it seems diagonal grain would break apart, but I have no experience with it. I'm finding nice solid looking, white holly, but only in short pieces so far. Its not cheap wood, so I dont want to order the wrong stuff.
For the teak, i will probably just buy 1/4" teak laminated plywood and cut it into 2.5" strips. I can source that locally. My biggest concern is the teak wont look the same. I know they used Burmese teak on the interior of my boat, but i'm not sure if thats the same for the floors. The floors i'm assuming were a more generic/standard premade laminate that was probably widely available back in 1980.
Also, any tips/trick/advice from anyone who has had to do this would be very welcome as well. I'm thinking of waterproof wood glue as the adhesive to laminate all of this with an epoxy coating on the bottom, varnished surface.
