I have a 2 year old Honda 2.3 HP Outboard. This season I hit the silt and mud at the dinghy dock. I bought this air cooled outboard just for this reason, the silt was ruining the impeller and water pump assembly on my Mercury.
I kicked up a heck of a lot of mud but went our way for the rest of the year.
While changing the fluids I tried to get the prop off but it would not budge.
I ended up having to cut a notch in the propeller to get a puller in place.
Finally got it off but found that the shear pin was bent and jammed in the metal insert housing in the propeller.
I never had a shear pin so bend drastically and not break. I would have welcomed that. Not to mention I am having a heck of a time trying to get the shear pin out. It won’t snap with pliers or cutters. I’ll end up cutting that off as well.
Have any others had this issue with their outboard propellers? The motor is always tilted up when we leave for the day, so it’s not sitting in salt water. I don’t give it a fresh water rinse though, don’t know to many that do. Maybe that’s the key.
Given that a new propeller is in my future, there are 3 types available. All metal propellers, all plastic (no metal insert) and the original plastic and metal insert.
What are your suggestions?
