I'm sure I don't know what you mean about making it personal. I'm sorry you took it that way.Well ya really didn't have to make it personal, did you?
ALL I have said is: sail on one tack and record the course. Sail on the other tack and record that course. The difference between those two courses is the goal to which you can steer your boat. Hope this helps.
I'm getting great advise and appreciate it all! I'm really good at sifting through the fluff to glean the grain from any conversation. IOW I think all the advise is good but only a portion of it applies to my boat and my particular goals from it. I just got back from the lake a few minutes ago, intending to try out my new Garmin GPSMap but the winds were very uninspiring so I never launched however. It may have to wait until next season to discover exactly how close (or far) from the wind the Merit will sail.I still don't understand what the quoted statement above means, but that's fine. I think Russ got good advice.
Yes, this is what I meant by the best rate for each boat and situation. Also, that the amount of rudder is subtly less when starting at full speed, and my increase as the boat slows. Many factors, and a carved turn is one good analogy.I'm a proponent of a short delay before releasing the jib. In addition to the reasons above, the wind pushes the jib over which I think is a lot better than the trimmer dragging the jib and sheets across the shrouds and the foredeck. The jib with wind in it wants to come over - let it. And the sail doesn't luff much.
As for maintaining boat speed through the tack, I think the biggest slow down is the rudder. You are supposed to carve a turn like a ski turn. At least that's the way we do it.
90% of the times I've been caught in irons in light winds it's because I didn't let the foresail backwind enough. I agree that conditions do dictate methods for sure.My boat is hard to tack. I've found how I tack depends greatly on wind speed. Below a certain wind speed, my boat isn't going fast enough to tack with the Genoa out, so in preparation of the tack, I furl it in, then tack and pull it out on the other side. Above that wind speed, I can tack with the Genoa deployed. However, there is a range between low and high wind speed where I will fall off slightly to gather speed, then tack. So it's not always the same method for my boat, depending on wind speed.
dj
When I began sailing I also thought that was true. Everybody was saying you need to back the jib on beach cats. But they were wrong. With expereince I learned that there are better ways.90% of the times I've been caught in irons in light winds it's because I didn't let the foresail backwind enough. I agree that conditions do dictate methods for sure.![]()
I like it! It's what I do most of the time single-handing my slightly larger boat.how'd I do?![]()
Ohhhh trust me.... Every day I've sailed over the past 12 years has been an experiment.I’d experiment with that anyway.
