Race intruder
NCBrew
Feb 22, 2010
79
Hunter Hunter Legend 35.5 9335 Albemarle Plantation, NC
Is there any lawful pursuit for a prior yacht club member with is now not a member, intruding in a scheduled yacht club race
Sounds annoying, but I think he’d have as much right to the water as anyone. What’s worse is that technically any interactions with him would be governed by COLREGS, instead of the Racing Rules of Sailing that everyone else will be following.
The only alternative I can think of is what some professional regattas and speedboat races do to get a restricted safety zone declared that the USCG could enforce. But that seems unlikely or impossible for the typical yacht club.
We used to put notice of our regattas in the Local Notice to Mariners. But that notice didn't entitle us to exclusive use of that area. The only measure I can think of is for the RC not to score the individual
Or is he being disruptive to the race? It sounds like there's a personal pique here. If someone wants to be an ass, and doesn't violate COREGS, I'm not sure there's any legal recourse. There is small claims court but what are the damages? Entry fees?
The OP didn't include details about the races, such as being exclusively for members. If so, is it in the NOR?
Apr 25, 2024
828
There seems to be a mindset among some racers that simply throwing out some racing buoys somehow changes the rules. And, they tend to set up right in front of a marina where non-racers are trying to come and go.
Just yesterday, after a long hard trip, I came home to discover a race set up across the bay in such a way that there was not reasonable way around their route. Given the choice, I would rather be courteous and go around, though I am not obligated to do so. I came in on a starboard tack, encountering several racers on a port tack. I made reasonable efforts to stay away from most of the action and chose the least disruptive route, but it did require a couple of racers to change their heading slightly. One waved and I waved back - no problem. The other was furious and cursed at us. Then another racer (who had completed the race) cut across our bow while we were taking sails down (away from the course), yelling something.
If I hadn't been so tired from hours of beating windward against a 2 kt current, I would have tracked down the race organizers and suggested they remind their racers of rules and basic manners.
Absolutely, most racers know the rules and they understand that their desire to race does not supercede those rules or reduce the importance of courtesy and safety on the water. But, competition tends to bring out the worst in people, and there are always a few that ruin it for everyone.
The bottom line, in response to the question, is that that former member could not only intrude on the race, they could fully participate, so long as they adhere to the COLREGS. There are RRS too, but they only apply among a group who are all race participants. That is, all racers can be bound by RRS, but that only governs their relationship to each other. A non-racer is not bound by those rules - only COLREGS. And, when asssessing any racer's relationship to a non-racer, RRS goes out the window and only COLREGs apply. (In fact, I think that is baked into RRS somewhere.)
Or, put another way, if someone is behaving in an unsafe manner or a manner which is inconsistent with COLREGS, then you could pursue the matter on those grounds. The fact that your club set up a race there probably isn't relevant. In fact, it could be argued that your club created a navigational hazard and had the greater duty. So, be careful about opening that box.
So, COLREGS apply to everyone all the time. But, there are some points in COLREGS that make this a little murky:
  • Rule 2(a): “Nothing in these Rules shall exonerate any vessel… from the consequences of neglect of any precaution which may be required by the ordinary practice of seamen.”
  • Rule 2(b): “In construing and complying with these Rules due regard shall be had to all dangers of navigation and collision and to any special circumstances… which may make a departure from these Rules necessary to avoid immediate danger.”
... which could be translated as ...
If you have no business being there, and you endanger other vessels, even if you are technically compliant with other COLREGS, you're still wrong. (This goes both ways, of course.)
So, the only leg you have to stand on here, as I see it is dependent on what exactly that person is doing in the race area and whether they are endangering other vessels. If they are merely an annoyance, there is no rule against that. If they are a hindrance that is putting other vessels at risk by, for example, unexpected maneuvers ... that sort of thing ... then they could be in violation of COLREGS rule 2.
If you really wanted to you could go to the organizing authority or race committee and suggest the cursing boats be held accountable under RRS 69, Misconduct. The rule text itself prohibits “conduct that may bring, or has brought, the sport into disrepute”.
World Sailing provides a whole guide on that rule at https://www.sailing.org/tools/documents/2017WorldSailingMisconductGuidance-[22804].pdf. They even include a section on Foul or Abusive Language. The overall intent of the rule is to improve sailors’ conduct and reduce exactly the type of behavior you’re seeing, so I think it would be fair, at least to consider a warning.
Tying this back to the OP, there could potentially be a rule 69 application there as well, against the “intruding” boat. If he’s going out onto the course in a deliberately malicious and spiteful way and causing significant disruption or danger then that could, maybe, be seen as misconduct. It would only impact him if he is also registered in another RRS governed event. It’d be a stretch, but if he registered for a different event, and then before that event concluded he conducted misconduct, your club could try to approach the other club’s organizing authority to have him disqualified under rule 69. I think this would be a really far stretch, and I’m guessing that he isn’t bothering to register in any separate events anyway, but that’s the only other option I can think of. If nothing else the threat of such a protest might be enough to get him to stop. All of this is, of course, assuming that he’s really doing this to be deliberately bothersome to you, and not just out to enjoy the day on what happens to be the same course.
Jun 17, 2022
551
Hunter 380 Comox BC
What do the collision regulations state? Are you in a closed off / restricted body of water?
Since the other boat is obviously not registered in the race, the Racing Rules of Sailing do not apply, only the COLREGs.
One of our local clubs sets their start line off a spit where 99.5% of local traffic pass.... needless to say, they sometimes have some pretty exciting starts, of no fault to general traffic.
PaulK
Dec 1, 2009
1,541
Sabre 402 Southport, CT
Judging by the different and quite varied responses it seems the OP"s question is difficult to understand. Does the prior YC member want to intrude in the race and is looking for a legal way to force himself in? Does the OP want to legally pursue the prior YC member because he intruded in a race? Typos (with instead of who?) do not make it easier to figure out. Why is the race a scheduled YC race and not just a YC race? What kind of intrusion is envisaged? Is he trying to enter a race which is only open to club members? Is he planning to cut across the race course on starboard tack and interfere with competitors? Is he a member who was expelled or did he resign? Can we find out what the question actually is so we can provide responses that make sense and are helpful?
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
I'm guessing that the "intruder" may be a disgruntled former race participant in the club. Probably the best course of action is to simply ignore the intrusion & not act like the intruder is getting under your skin. Sure, he may be cutting thru on stbd tack and possibly even cutting thru on port tack, just to make stbd tack boats avoid a collision. Where is a colreg complaint ultimately going to go when everybody is essentially just pissing into the wind? That's probably the intruder's goal.
After one or two unsuccessful attempts to get everybody excited, hopefully the intruder just goes away. Or, if he is actually just joining the race casually and not getting in anybody's way or impacting any results, where is the harm done?
I'm guessing the coat guard would be willing to give him a talking to
Probably not. And if the YC has not notified the CG of their race schedule, they may get a talking to.
This is really simple.
All boats, racing or not, should follow COLREGs and the rules of the road. And in COLREGs, and the RRS, the last boat that has the opportunity to avoid a collision and doesn't is at fault.
With regards to the racers, the intruding boat ranks as an obstruction and the RRS apply to boats dealing with obstructions, basically, you can't run your opponent up on the rocks (or into an intruding boat).
I understand the passion, frustration, and anger about this boat, but none of those emotions matter. The guy has a right to free navigation and unless it is a high profile event (Think America's Cup) and the CG deems that restricting access is necessary, he can do what he wants on the race course. Getting angry, making threats, or flipping the guy off might make the racers feel better, however, the intruder is doing this to get a rise out of the racers, ignore him or better yet treat him in a friendly manner. He wants the emotional response, don't give it to him. He'll go away.
