Painting Boat Bottom.....Copper Free Ablative Paint??
Sep 8, 2025
126
Bayfield 36 Lewisporte
Hi,
Any recommendations on which ablative type paint to use? I was looking at the "Total Boat Krypton" which is copper free. But there is also the "Total Boat Spartan" which contains copper. Is there a difference in performance? Would you recommend a different paint?
Is bottom painting a once per year requirement?
Thanks
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
Hows it going buddy ?
AntiFouling paint choice depends on where your boat is, how long it's in the water.
How often it needs to be refreshed depends on the paint, how thick it is, boat use.
You have a Bayfield in Newfoundland aka cold saltwater ? Are you keeping it in the water year around ?
What are the local fishermen there using ? They are pros and would know the local growth conditions.
You won't have to really worry about this until next spring. In the meantime, ask other boat owners in your marina what they use. Each harbor different and what works well in one harbor doesn't work at all in another.
Sep 8, 2025
126
Hi :)
I guess the plan will be to sail it in warmer waters (Caribbean/Pacific) and most likely in water all year round.
Keep in mind the copper free types still contain a biocide, so if you’re looking at copper free from an ecological perspective it’s still not perfect. I think the biggest reason for copper free is compatibility with hull or drive housing materials like aluminum that would react with copper. I’ve always assumed the non-copper alternatives trade off antifouling performance for that compatibility, but I don’t know that for sure. As others have said it’s probably very dependent on water type and temperature.
Sep 8, 2025
126
Ah, thanks
So, having a fiberglass hull then I should go with a copper based one?
Bottom paint performance is associated with the waters you sail and the frequency you sail or clean the bottom.
In cold ocean waters multi-year performance is possible. I’ve used Trinidad by Pettit paints. I get 3-5 years between paint jobs. Going out at least every 6 weeks and bottom cleaning by a diver 3 times a year has made me happy about my boat bottom.
Sep 24, 2018
4,448
Catalina 30 MKIII Chicago
@GeneraiT001 Call local yards and chandleries for their recommendations. Bottompaintstore.com has some informative articles as well
How many layers did you apply?
Likes: GeneraiT001
Since both of the products you’re looking at are Total Boat you could also call them. They might be able to provide advice on which one generally works better in some types of water. In my experience their customer support is very good.
I applied two coats across the hull and a third coat on the leading edges of the Rudder, Bow, Keel, and bottom of the keel. When I hauled the boat, the paint still covered the hull, but the leading edges showed wear.
Launch March 2018
At haul-out Feb 2023.
After Pressure Washing. Current Hull paint is Blue. The previous layer was Red
New Paint Job. Black like the whales.
Likes: JamesG161
Sep 8, 2025
126
Launch March 2018
View attachment 234367 View attachment 234368
That looks great....I long to be at the point of a completed painted hull!! :)
JBP-PA
Apr 29, 2022
782
Jeanneau Tonic 23 Erie, PA
I used to use copper based paint and switched to Krypton. I haven't noticed any difference in effectiveness. Krypton does smell much worse than the water based paints. On Lake Erie.
Likes: GeneraiT001
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
I would use coppercoat or similar.
But...I would ask the local fishermen. Commercial paint is often better and may be cheaper, than "yacht" paint
For example copper coat commercial makes a 30 year claim.
If you are in saltwater... Then get info about saltwater. Freshwater boats have it easy.
Sep 8, 2025
126
3,943
Corsair F-24 MK I Deale, MD
Hi,
Thanks
At least in this test, Krypton was better. (I tested 30 paints for Practical Sailor, 2 years plus, panels and on boat.)
I'm now using Krypton on my personal boat. Based on the last two years, I'll probably be using it again.
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
I notice that commercial paints are not usually part of these tests. For example, Sherwin Williams has a product line I recently became aware of via commercial fishermen I was chatting with.
Any idea if there is a legal restriction in North America on using them for non commercial applications ?
Mar 26, 2011
3,943
No, it just was not the focus. Distribution is different.
I did use a Sherwin Williams paint on my boat many years ago. It wasn't really any different from equivalent yacht paints. There is no special sauce.
Mar 20, 2015
3,304
C&C 30 Mk1 Canada
The fishermen told me that the commercial stuff is cheaper than paint marketed for the yacht market. Not sure if that's just the stuff they use, or what. Personally I wouldn't be surprised.
Fwiw The life expectancy of "Commercial Coppercoat" apoears to be higher based on the mfg website. Not sure if that is due to mil thickness or what.
<Dunno/Shrug emotion here>
Be interesting to compare.
