First Day out on the Hunter 240
Jun 10, 2024
255
Hunter 240 Okanagan Lake
Towing the 240 is ok. It is on the wider side but you get used to it. Keep the left wheel close to the centre line and the right wheel won’t go off into the shoulder or hit the curb.
We decided to load the vessel and not step the mast right away. Sunday morning at the boat launch, we wanted to get it in and get a parking spot. Success but I held the ramp up with our engine not starting. We pulled the 240 out of everyone’s way on the other side. I was actually able to reach the engine better, first pull and we were on our way.
The cockpit is huge. Lots of room compared to the C&C 27 we race on. My only complaint, we have no cushions and the floor is too high. Change is needed here. Test one, dropping the centre board. I was so hoping it would go down and stop before the double fisherman knot hit the pulley, it did. It lowered fine and the knot has at least 3 inches of clearance. Awesome! Test two, open the water ballast valve. This one was intriguing lol. I stayed below with it, looking around. Searching for water in all areas. You can sure feel the wind coming out as the water enters. I could start to see the water and tried waiting until I could touch it with my finger. It never came high enough. I closed the valve installed the plug, success. Stepping the mast on the water was accomplished well because of the lifting system, boy it works slick. I will not however do that again. I was unable to safely adjust/tighten the shrouds. I settled for, that will be good for today. We shifted our attention to the cabin. I went under the cockpit, it’s tight. I checked the bilge pump area and other access panels. We were completely dry. No water entered the vessel. The V berth didn’t look large enough for Michelle and I to sleep on. Sleeping arrangements was a concern for me as Michelle already said the Mac25 wins in that department. WRONG, we were both pleasantly surprised. We both fit with room to spare on the V berth. Next test, lunch time. The table included is solid and large. We were very pleased sitting down at the table eating. Lots of room, great view out of the windows too. I quickly checked the water ballast. The water did not come any higher, all was still good. The table mounts outside on the cockpit too; we never did try that. This entire time the temperature was in the mid 90’s and we had no wind. It was hot. The easy access to the water, incredible. Michelle’s favourite. Larger waves and rougher water, we felt quite secure. The Mac25 did well too with the heavier keel but we really did feel more stable. I could see some wind coming. We decided to hoist the main. With all of the fun we had I never realized how far down the lake we floated. I decided to start the engine and power gibe back. Lol. I would say we never really did get to sail her but we sure had a great time. A few times I powered back feeling more wind but .5 knot was the best we could get. We had great timing as we approached the dock, we were first on a double ramp setup. We docked it like we have been boating for years lol, felt great. I got the trailer under her and pulled out, and back in, then out and back in etc. etc. I could not get her to sit on the trailer properly. Finally I was ok with it. I started to pull further and I could feel the trailer tire drop. My truck wheels starting spinning. Hmm I thought. I put it in 4 wheel drive and out we came. I pulled over once I was a bit clear of the ramp. I commented to Michelle on how that was a different experience. It was at that point I said water ballast, I never considered it the entire time. I jumped in and opened the plug, Michelle walked away, she was embarrassed with the amount of water. It was all heading back the lake though :)
We unstepped the mast, (so nice to do) packed everything up, did a walk around and Michelle says, UHOH. Turns out a bit too much force was applied pulling and obviously a weak weld let go. The shackle broke off the left side of the trailer and the axle moved back 3 inches jamming the left tire against the fender. We hugged and laughed, what a bad ending to a great day lol. Michelle made it home way before me thanks to her sister rescuing her. I did make it home eventually with the boat and trailer. I now have a quick weld to do lol.
Question, I have no doubt both the condition of the ramp and the added weight of the water filled vessel contributed to this. What could I have done different?
Thanks for the nice write up. It’s fun to read about other people‘s adventures.
I would never step a mast on the water again. I’ve made that mistake once and while the mast was about halfway up, a power boat came by threw a big wake … rocked my boat, the mast went sideways a shroud broke and almost lost the mast Overboard.
Lost about a month of the sailing season getting all the parts I needed to fix it.
I have a checklist of things that need to get done and the order they need to occur in.
It helps to make sure that you don’t overlook something. This will be very important after a long day when you’re tired and exhausted.
A mistake that I think you made (but it seems like you survived) was stepping your mast without filling the water ballast tank That could’ve turned ugly fast. Again, a checklist of things that need to happen and what order they need to happen in will prevent any future issues.
Sounds like a successful shakedown cruise and you learn some things and had some fun. Congrats.
there’s no such thing as figuring it all out when it comes to a sailboat. Every time I go out, I learn something and discover a way to do something better. I think that’s why I love sailing so much.:beer:
One more thing.
I recommend in the future you step the mast in the parking lot. The ballast tank valve should already be open, because you opened it the last time you took the boat out of the water and you left it open. There should be a ring attached to the threaded rod of your ballast tank bar. That ring is to prevent the threaded rod from rotating while you’re driving down the road and your ballast tank cover falling off the boat while you’re driving. Make sure that ring is there.
Back the trailer into the water with the mast already stepped and wait for the ballast tank to fill before you walk the boat off the trailer. This will piss all the power boaters off so… If you can find a ramp, that’s not too crowded then that’s your go to ramp.
I remember seeing a post from about eight or nine years ago where someone forgot to open their ballast tank and backed the boat off the trailer with the valve shut and the boat rolled over on its side. Fill the tank while the boat still on the trailer.
Jun 10, 2024
255
Thank you for the feedback. We always step our Mac25 on the hard and then go in the water; not sure why I chose different. Excitement I guess finally getting her out I didn’t want anything to stop us. I never thought about filling the tank prior. I’ve read a few folks don’t even fill the water ballast, not a fan of that. The ring is on for sure. A check list is in the making for the Hunter.
Thanks again
Jun 10, 2024
255
We’re fixed and ready to go again. My son came by and we welded the trailer shackle. We actually strengthened both sides. I was talking with another gent, he said be careful if you ever unload at paddle wheel. He said they hit a large hole pulling out their pontoon boat. I said, that’s where we were when this happened.
I guess I’ll make a few calls and see what we can do to help fix the boat ramp.
Likes: rgranger
Jun 10, 2024
255
Taking the 240 out again today. I will step the mast and tighten the rigging on the hard this time. I’m going to use the other side of the boat launch today. The ballast valve is open, I will leave it open now that I know I don’t have to watch the level closely as I put her in the water. One of my concerns, loading her on the trailer again when we’re done with the ballast tank full.
I read somewhere folks are using an air pump to blow air in and the water out. Is this ok to do?
Hoping for the perfect wind.
there’s someone on here that uses the air mattress pump. I don’t know how well it works.
I’ve never had trouble getting on the trailer with the ballast tank fall. Just pull out slowly with the valve open.
Sep 30, 2016
391
Island Packet IP 44 Ventura, CA
I always just opened the ballast valve just after loading on the trailer. Then load up and pull her out. Its was never a problem driving a couple of hundred yards at parking lot speeds and letting the water drain out while I de-rigged the boat. It drains fast. Blowing it out with air is completely unnecessary and way overkill. In fact, pressurizing the ballast tank enough to force the water out while the boat is still afloat seems sketchy to me.
Likes: rgranger
-na -NA Anywhere USA
Thank you for your write up. May I suggest choking your truck tires when attached to the trailer parked heading upwards for added safety if working on the trailer.
Jun 10, 2024
255
Thanks guys! It was a good day but forecasted winds left us alone. I think we seen 1.2 knots again. That said, more weight on board was good to experience. Once prepared, I backed her down knowing the ballast plug was open; she left the trailer with no issue. 3 jumped on board and the movement got attention. I boarded, no water was entering the ballast tank. I gently pushed on the valve and held it for a few seconds and then I was able to walk away while it filled. Comments after, that feels much better now. I lowered the centre board. Sailing was uneventful, company was great.
She nestled onto the trailer with the ballast plug open. I did pull forward enough to see how she was sitting. That was enough to hear the ballast water exiting. We waited until it almost stopped, I can’t give a time, too much fun but it wasn’t long, minutes.
We pulled her the rest of the way out.
