0.04 or 0.06" seizing wire for turnbuckles?
Nov 6, 2020
487
Mariner 36 California
I think i'm going to use seizing wire for my rigging turnbuckles instead of cotter pins. Ordering some from McMaster. Trying to decide diameter to get and am trying to remember what I ordered last time. I think it was 0.04". That sound about right? I was thinking 0.04 or 0.06".
JRacer
Aug 9, 2011
1,380
I use these available at defender.com. Not inexpensive but I get many years of use out of them. Beat me to it, DL.
C.S. Johnson Hook and Loop Locking Wrap Pin
I know that by definition sailors have deep pockets. But seriously, 20 bucks each? To each their own. YMMV.
That's ~$20 a pair. I cringed when I saw that figure too. With 8 tunbuckles, it was a lot of money. I purchased mined over time, by throwing a pair in the cart on any Defender order. I think it took about a year to get all that I needed. An extra $20 every now and then doesn't hurt as much.Since we take the mast down every year, eliminating the hassle of pulling cotter pins every year was worth it. Also, it is much easier to retune the mast midseason if needed.
JRacer
Aug 9, 2011
1,380
I think I bought my set in 2012 when we bought the boat as I had used them on my J24, quick and easy to remove and replace to tune the rig between races and the wrap covers the pin so no risk of fastener tears to the genoa! So, at today's price a set for the four shrouds is $72 bucks / 13 years amounts to $5.53 per year for all. And they are still usable! And any damage to a genoa from a cotter pin or ring would far exceed the cost of the protective wraps. Good value as I see it.
Likes: Timm R Oday25
Nov 12, 2009
275
J/ 32 NCYC, Western Lake Erie
[I use Wrap Pins. Quick and easy. No tools needed.]
For all of you who have already bought Wrap Pins don't read any further.....
For all you (frugal) DIYers, you can buy all the velcro and cotter pins you will need to make your own for 20 bucks.
Buy the right diameter cotter pins for your turnbuckles.
Cut to length so they just stick out the other side of the turnbuckle.
Cut a length of double sided velcro (we use 3/4 inch) that will wrap around your turnbuckle about one-and-a-half times.
Sew the cotter pin to the velcro in an appropriate spot with heavy thread.
Stick the pin through the turnbuckle hole and wrap velcro around an back on itself.
3,801
Corsair F-24 MK I Deale, MD
Curiously, I've been moving away from rings and towards wire over time. It seems easier to deal with and failures are less common IMe if done properly.
The only failures relate to tightening them by twisting. Wrong. That will break the wire. Pull snug, 2 wraps if there is room, and then twist 8 turns per inch under modest tension. Do NOT use the twisting process to tension the wire. Its purpose is only to hold the ends from slipping. Trim and tuck the end. This is how it is done on aircraft. 0.040 is plenty, monel if you can find it (more malleable). It will not break if properly installed. Over twisting is what causes the failures. The aircraft guys have literally written the book on safety wiring method. safety wire practice
Nov 6, 2020
487
Have you considered stainless split rings? They're inexpensive, simpler to use, and reusable. That's what I use.
Not a fan. I have seen a few get all bent out of shape from random snags. I got a rope stuck on one on my friends boat, gave it a good tug not knowing what it was hung up on and deformed the ring pretty badly.
Maybe they were just undersized though and larger diameter rings are much more durable? Seems like the seizing wire will be easier to tuck snugly to prevent any snags.
Likes: degas
Nov 6, 2020
487
Thanks for the link. Yeah i find myself moving away from pins and rings as well. Im using wire a bit more now. I found a roll of .050" 316 stainless in my rigging bag, so am using that for now since I have it, but McMaster Carr has some nickel .060. Its $100 per spool though. Will grab a spool next time i order from them.
Likes: BAD ORCA
JRacer
Aug 9, 2011
1,380
Interesting idea, but i have had bad experience with UV and velcro wraps for other stuff.
These must be UV tolerable as mine have lasted a very long time and are UV exposed 6 or more months of the year.
Jun 14, 2010
2,392
Color makes a big difference. White degrades quickly, whereas the UV is blocked by pigment from penetrating black or dark colors. Same with sails and lines. Black dock lines last longer, as do darker colored panels in sails.
