House batteries not charging when engine running
Jul 16, 2016
70
Hunter 410 Ventura
I was taking my first shakedown passage on my Hunter 410. I noticed that under engine power my house batteries were reading 12.4 volts. My starting battery read almost 14. This told me that my house batteries weren’t charging. As the trip wore on battery voltage dropped to 12.2 or so and I decided to turn around. Back on shore power now and house batteries are over 13 volts again apparently charging.
Batteries never get over 12.4ish volts. No clue how old the house batteries are. Not sure this is just a bad battery situation or more to it? I assume alternator is ok as it’s charging the starting battery fine
Sep 30, 2016
379
Island Packet IP 44 Ventura, CA
You need to put a volt meter on the house and start battery and see whats really happening. If the alternator is not getting power to the house battery determine where the connection is lost. But its concerning that you are only seeing 12.4 V maximum from your house batteries, even after being charged from shore power. Thats why I say you need to measure the voltage with a volt meter and see what you are really getting under shore power and alternator. Im assuming you have lead acid batteries. 12.1 volts is typical for 50% charge. You shouldn't let them get below that, if possible. And if they really wont get above 12.4 volts with a proper charge, they are done.
Jan 7, 2011
5,685
Oday 322 East Chicago, IN
I depends on how your alternator is wired to the batteries. My old system had the alternator output backfeeding to the Common post on the 1-2-Both-Off switch.
I recently switched the house bank to LiFePO4 and separated the house and starting circuits. The alternator is now feeding only my lead acid start battery (I don’t want the LFP BMS from shutting down and frying the alternator).
Or you may have an ACR or DC-DC charger in the circuit that is t working.
You need to start tracing how your batteries are and alternator are wired up.
If you’re seeing 13+ on the shore charger but decreasing voltage when the engine is running is means the alternator is not charging the house bank. You’re seeing 14 V on the start battery so the alternator is functioning. This all suggests you have a wiring or switching issue, not that a bad battery is the cause. You’ll need to trace wires to see how the alternator is intended to charge the house bank, whether that’s through a switch that’s in the wrong position, a battery isolator, or a bad wiring connection.
Likes: degas
Jan 7, 2011
5,685
You may also have some old, tired batteries since the voltage is dropping seemingly quickly when off a charging source…but that is a separate issue. My 5-year old 6-volt golf cart batteries were showing 13+ volts when I left the dock and while motoring, but the voltage dropped quickly after I shut down the engine. I replaced them with 2) 12v LiFeP04 and they stay at 12.8v or more while sailing.
A load on the batteries may drop the voltage, so you might want to charge them up at the dock, then turn off the charger and see where the batteries end up once they are at rest for a few hours.
7,472
Alden 50 Sarasota, Florida
Start with the easy stuff first.
check the battery isolator or ACR relay.
if you have an isolator, what you see is normal given the inherent voltage drop.
Likes: JamesG161
Jun 17, 2022
264
Hunter 380 Comox BC
Sounds like you are on the right track by monitoring battery voltage under various vessel conditions and you've narrowed it down to power generation while disconnected from shore power and while under engine power (so we can rule out the AC charger which probably has 2 sets of wires, one for each bank).
Assumption: a) you have flooded/agm cells and not lithium b) the previous owner did not do "improvements" aka modifications...
1) Do you have the Hunter owner's manual for your boat? They usually have pretty good electrical diagrams that show how the DC system is wired, including the battery combination method.
2) Does it appear the previous owner modified anything ?
3) What does your start/house battery switching arrangement look like?
4) Can you take a look behind the battery switch panel and take a good photo?
Likely scenarios: There is an automatic relay, that either latches based on alternator output voltage or should latch automatically when the ignition is active. On my boat, there was a breaker that had to be toggled once the engine was running to latch the solenoid, combine and charge both banks after the engine started.
If marine electrical is all new to you, it might be worthwhile to pay a good marine electrician to survey the electrical of the boat from end to end.... usually takes about 3-4 hrs plus report writing time. That would give you a better understanding of how your boat is currently wired and what systems may need attention/maintenance.... There's no point to blindly start replacing stuff (like batteries), without understanding the state of the overall system...
Recommendation: install a battery monitor. Voltage isn't the whole story....
Example:
BMV-712 Smart | Victron Energy OR
They give you excellent tracking of the remaining capacity and state of charge of the house bank and also tracks start bank voltage....
Likes: CrispyCringle
It is common for production boats to have the alternator output go to the starter post. This does several things, shortens the wiring run from the alternator, speeds installation of the engine and electrical system, and reduces warrantee claims due to operator error. It does not reduce the chance of operator error deeply discharging the house batteries and perhaps murdering them.
The place to start is the article below. This will give you a deeper understanding of the battery switch and your electrical system. Armed with the information in the article you will be better able to diagnose the problem, which maybe a simple change in how you manage the battery switch.
Jul 16, 2016
70
Hunter 410 Ventura
My older boats had the 1/2/both switch, but this one is more complicated. It has a starting system on off switch, an inverter draw switch with breakers for each panel and a remote interface. I've gone through the manual on this a couple times since I've purchased the boat and think I have the right idea of how to switch it in each of the running states.
My gut feeling is that the batteries have been discharged below 12 volts many times and they are junk. There was apparently a college-aged girl living aboard this thing periodically over the last couple of years and it's been a dock queen for 10 years. Engine maintenance hadn't been done in 10 years and only 40 hours on the engine in that time. So it has no doubt been at least 10 years since the batteries have been addressed.
They are sealed AGM batteries
If it was a dock queen living on shore power that doesn’t suggest the batteries were deeply discharged often. At 10+ years they might be past their prime, and that might explain why they quickly drop to the lower 12’s when not charging, but I still don’t think that explains the sub-13V readings when the engine is running. Your shore charger can get them over 13V so they aren’t shorted internally and sucking more current than can be provided. The alternator should be able to get them at least as high as the shore charger if it’s switched or combined properly.
Yep, the batteries. AGMs are notorious for failing if they are not maintained at 100% SOC.
Check to see how the batteries are combined for charging, there are several ways to do this. If you have a diode based system, time to upgrade. Diodes drop the voltage so that the batteries are not charged at the proper voltage. An ACR or a DC-DC charger will work better. The DC-DC charger is a better choice if an upgrade to LFP is in the boat's future.
JamesG161
Feb 14, 2014
7,803
Hunter 430 Waveland, MS
His H410 used to have old version of the ACR Relay, that only worked when the engine was running. The relay failed too many times.:facepalm:
On my H430, I have a new ICG that needs shore power or my Genset to charge House Batteries.
Jim...
Feb 16, 2024
43
Hunter Legend 37 Gig Harbor
How should you charge your LiFePO4 batteries when not on shore power?
7,472
Jim...
Good upgrade. This problem walks like, talks like and sounds like a typical charge relay problem often overlooked in favor of far more costly wild goose chases. But we tried…
Likes: JamesG161
JamesG161
Feb 14, 2014
7,803
I suggest they get the H410 owners manual download it here
H410
This is my H430, note the Start Batt and House Batts are separated!!]
Hope this helps
Jim...
Jul 16, 2016
70
Hunter 410 Ventura
I'm seeking out simpler solutions first so I'm going to make sure I understand how the charge relay system works from the alternator. I'm relatively certain I need new batteries either way, but to someone's point earlier, it seems to me that when the engine is on the voltage should still be going up over 13 volts.
The reason I suspect the batteries have been drawn down numerous times is because while I was in the long process of buying her, the selector switches were left in all sorts of crazy positions and combinations without folks seeming to know how to work them. From my reading in the manual, the inverter draw selector acts like a 1/2/Both switch when the inverter remote switch is off. So leaving it in the off position while on shore power means they are getting no charge. I found the switches that way many times upon returning to the boat.
JamesG161
Feb 14, 2014
7,803
ok i found this in H410 Owner's Manual
Note page # on the left.
Others can chime in to help you.
Jim...
