Well, I was minding my own business at the yard the other day, when I saw a couple of other folks poking around their rudders. Naturally, that got me curious (never a good sign for my wallet).
So I go to check mine, and what do I see? A little bit of water seeping out. Being the rational, cautious boat owner that I am… I grabbed the angle grinder.
One thing led to another, and… well… you can see the carnage in the pictures. I traced some hairline cracks and found water lurking inside, so I kept chasing them. Turns out it wasn’t just a couple cracks — it’s a full-blown “let’s open up the patient” situation.
I’ve let it dry for a couple days (and will probably give it a bit more time), but I’m going to have to rebuild. My current plan:
Fill the internal voids with West System epoxy thickened with 406 colloidal silica
Lay up 17-oz biaxial cloth with epoxy over the repair area
Seal the whole thing with an epoxy barrier coat
Finish with ablative paint
It looks like someone repaired this rudder skeg before, but skipped the barrier coat. That let water in, and with freezing/thawing cycles plus rudder loads, cracks formed. This section I opened up is forward of the rudder — the part that connects to the hull (skeg).
Anyway, now you know my plan. I’d love to hear tips, horror stories, or “don’t do that” advice from folks who’ve been down the rudder-repair rabbit hole before.
And yes, I realize this all started because I couldn’t mind my own business.
