Mariner 19 Vang vs Gnav
Mar 3, 2025
3
O'day Mariner 19 3354 Monticello, IN
Hi all! I need to upgrade the vang on my Mariner 19, and I'm a little torn on which way to go. The Mariner 19 essentially shares a rig with the Lightning, as well as it's sister ship, the Rhodes 19. The Mariner, however, because of the added sleeping quarters, has a 1' shorter mainsail, and subsequently a poorly angled vang. Right now I have the factory 3:1 vang with a v jam cleat (that doesn't hold) that's about 30* between the boom and mast. Most Mariner owners seem to stick with the shallow angle vang and just increase the advantage so something like 16:1+/-. Some add a mast baseplate or pad eye just aft of the mast to improve the vang angle, which does help a fair amount, but still isn't a 45* angle.
I'm torn between adding a pad eye as far aft of the mast as I can get away with and using a rope vang, or making a Gnav. I'm having a hard time find examples of Gnav on boats around the size of the mariner, but given the shallow angle of the vang, I'm wondering if that doesn't make more sense in this situation. That said, improving the current vang set up would be quite a bit easier. I do race fairly often, just for context, but my boat is already not class legal, so that's not a consideration.
So my questions are:
Is there any practical difference to sail shaping between the vang and the gnav?
Does a gnav cause any more stress on the boom than a normal vang? (The boat is currently set up for mid boom sheeting, but I will be converting it to a Crosby rig or something similar, if that has an effect)
How much of an effect on sails shape is there by having the gnav interfere with the tack of the sail on port tack?
Is there a reason gnav seem to only be used on dinghies? Or is it because boats the size of the Mariner or bigger generally have enough room for a vang?
The vang is a pretty crucial piece of equipment on the Mariner. (Maybe a lot of boats, I'm new to sailing.) Without it, the boom can easily raise and catch the backstay in a gybe. This happened to me this past weekend because of the current faulty vang. Luckily it didn't cause any major problems this time, but I need to make sure it doesn't happen again!
I can't comment on the gnav because I don't know what it is.
The only comment I can offer is that if you move the vang aft on the boom you may cut off access for the crew to cross the cockpit during tacks.
May 12, 2025
45
Macgregor 22 Silverton OR
Vang spelled backwards does not seem to be the same as use less vang though I am not sure why. I'm beginning to think it's like trying to explain how to stop on a hill to someone who is learning to drive a car with a gear shift and a clutch.
Mar 3, 2025
3
A gnav is a rod that forces the boom down from the top, as opposed to being pulled down like a regular vang. They are becoming increasingly popular on smaller craft because it clears the front of the cockpit some. The Mariner has more cockpit than some 30 footers I've seen, but the cabin interferes with the angle of the vang, hence why I'm considering changing it.
Likes: LLoyd B
pgandw
Oct 14, 2023
167
Stuart (ODay) Mariner 19 Yeopim Creek
With my Mariner, I did 2 things:
  • base plate for the mast. However, have to be careful when lowering the mast - a cleat at the bottom of the mast slot will hang up on the base plate when lowering the mast. Ask me how I know.
  • replaced the useless v jam with a block with a cam cleat. Wondered if I needed more purchase, but it turns out the 3:1 with a proper cam cleat works just fine for me.
I've never seen or heard of a gnav, so can't help there. The modified vang works just fine for me, even though the angle is still pretty bad. Money being no object, I would have replaced the top block to get a 4:1 purchase. Vang gets removed for trailering. Here's a photo of the new lower block for the vang.
Fred W
Stuart Mariner #4133 Sweet P
