Prop Halo?
Tedd
Jul 25, 2013
793
TES 246 Versus Bowser, BC
I'm posting this in the PNW forum because I suspect the product I'm looking for may only be common in the PNW area.
I'm looking for a propeller guard called Prop Halo? Does anyone know where I can get one?
I've seen them on many small outboard motors in my area (the strait side of Vancouver Island). Many fishing boats around here have them. Web searches turn up either other propeller guards or Halloween costumes (as in a stage-prop halo).
Tedd
I have seen them on outboards. Are you suggesting putting them on an inboard prop?
You may likely need to have one manufactured.
I might expand my search to include "prop guards".
Tedd
Jul 25, 2013
793
No, I have an outboard on my boat.
One of the problems with my boat is that if the kick-up rudder kicks up while you're turning and motoring it can go right into the prop. I had to replace my prop because of that. (It doesn't do the rudder any favours, either.) I'm looking for a way to protect the new prop.
Johnb
Hunter 37-cutter Richmond CA
Google outboard propeller guard and make your choice
Tedd
Jul 25, 2013
793
@Johnb ,
As I said in my original post, I'm actually looking for this specific prop guard. And I have been on the internet before.
Jan 5, 2017
2,464
Not sure where you are Ted but can you find one on a boat near you and ask the owner?
May 7, 2012
1,573
Hunter e33 Maple Bay, BC
If Google doesn't come up with the answer then maybe try asking those boat owners that have them where they sourced their Prop Halo. Tedd does it look something like the one in this photo?
Tedd
Jul 25, 2013
793
I did ask one owner while he was launching his boat but he got the guard with the boat and didn't know where it came from. Generally, of course, the owner isn't around. Perhaps I'll try leaving notes on boats but I haven't had much luck with that approach in the past.
@Hello Below ,
That's a similar name brand but it's not like the one I'm looking for. The Halo Prop model is a very simple hoop of tubing in the plane of the prop. I like the simplicity of it. Unlike fishermen, I'm not looking to protect my prop from debris, weeds, or fishing lines, so I don't need all the mesh and other features that many guards have.
May 7, 2012
1,573
Tedd, when you next get to the big city, drop by or phone Victoria Propellers. They have 2 locations: one in Cobble Hill (Steve McPherson) and one in Nanaimo (Steve's son). They live and breath props and maybe a start point.
Likes: Tedd
Tedd
Jul 25, 2013
793
@Foswick ,
It's a bit like that but the Prop Halo is a hoop of plain round tubing. (Or possibly round bar.)
Do you know what brand that is in your photo? It looks like it might be an option for me. How the heck does it mount? It looks like it's just dangling from the anti-aeration plate.
Apr 25, 2024
694
Fuji 32 Bellingham
All I know about it is that it showed up in a search at: Log into Facebook Someone just up the road, in Campbell River, was selling a couple of these, which made me think it might be what you were looking for.
I also wondered how it mounted, but I noticed there is a second picture on that ad that shows some bolt holes. It appears it was just dangled in that photo so show what it for, but that it actually bolts on.
Jan 5, 2017
2,464
That might have been a good choice for me.
That one looks really simple to make. A piece of 1/4 in. aluminum flat bar the right length, a forming jig, a little heart and Bobs your uncle. Or take it to a place that bends things but I would do it myself.
Tedd
Jul 25, 2013
793
@Michael Davis ,
Yeah, I'm thinking about it. I've started on a CAD model for one like the Prop Halo, which I like better.
The fisherman on my dock has this for his small kicker outboard.
It is a hoop around the blade. It is attached to the plate above his prop.
Likes: JamesG161
Catalina 36mkII Alameda, CA
Is this something you may be looking for?
Tedd
Jul 25, 2013
793
I wish I could just upload a photo of a Prop Halo so people could see exactly what it is I'm looking for. But, of course, the whole point of my post is that I can't find even so much as a photo of it on the web! But thanks to everyone for your help. If I do find out where the Prop Halo came from I'll be sure to post that here, for posterity.
Since this has continued to bewilder us, I contacted ChatGBT to enlighten me about possible images of a "Prop Halo".
At first, ChatGBT seemed as baffled as we have been, so I changed the wording and the sequence of words.
Finally, using this group of words: "Halo device for a boat propeller"
I got back these responses:
A “prop halo”—in the context of boat propellers—refers to a simple, minimalist form of propeller guard. It consists of a thin hoop, typically a stainless steel rod (around 5/16”), mounted in the same plane as the propeller and just a few inches larger in diameter. This blunt but effective design helps prevent objects, rudders, or limbs from colliding with spinning prop blades.
What Is a Prop Halo?
• Design: A circular ring—generally about 4 inches larger than the prop’s diameter—positioned around the blade plane.
• Purpose: To physically block accidental contact with the spinning blades, especially useful for preventing interference from rudder movement or nearby debris.
Advantages
• Simplicity & Robustness: Straightforward mechanical design that’s easy to install, maintain, and repair.
• Low Drag Impact: Especially at lower speeds (e.g., below 5 knots), the drag penalty is minimal. Many boaters find it practical for casual or slow cruising use.
Alternative Propeller Safety Devices
For broader protection, several other types exist:
Device TypeDescription
Cages / ScreensFull or partial encasements around the prop that offer extensive protection.
Shrouds / RingsSimilar to prop halos but often more streamlined and integrated.
Deflectors / NozzlesWater-flow optimized guards that can improve efficiency while protecting.
Safety CoversRemovable covers (like the PropPro) to prevent injury when the boat is inactive
These devices can dramatically reduce propeller-related accidents. Studies show that guards can prevent up to 90% of these incidents, with a negligible effect on speed or fuel efficiency when correctly installed.
Should You Consider a Prop Halo?
• Use Case: Great for low-speed recreational settings, especially where the main concern is rudder bumps or occasional contact from inboard structures.
• Simplicity Is Key: This is ideal if you prefer an unobtrusive, mechanical solution without complicated brackets or performance trade-offs.
• Higher Safety Needs? If you contend with swimmers, marine wildlife, or often operate in tight spaces, a more protective guard (like a cage or ring) might be a safer bet.
Good Luck.. We all know this is just a differential search of internet wording associated with the sequence of query words.
