M25XPB fuel starvation
Aug 1, 2023
7
Catalina C36 Port Townsend
I need help from anyone that is familiar with these engines. I was running the motor after it had sat for 6-8 months straight (I believe I put stabilizer and biocide in the tank at the last fill-up, but that was probably last fall). Anyway, it started right up after the long off-season, and I was running the motor at idle for about 20 minutes with no issues, when all of a sudden it sputtered and died. Since then, when you start the motor it fires right up, runs for almost exactly 40 seconds, then dies, every time. I figured air in the fuel system somewhere. So I bled it out, first at the spin-on fuel filter, then the injection pump, then the injectors themselves. No change. I changed the fuel filter and racor. No change. I removed the injection pump and cleaned it as best I could with seafoam. No change. So I’m basically stumped here. Tomorrow I’m going to unhook the fuel tank from the lift pump and run a temporary fuel line into a jerry can full of fresh diesel to eliminate the possibility of upstream issues and fuel contamination/deterioration. But I’m pretty much out of ideas. Any advice? Thanks
Likes: Timm R Oday25
Yes the symptom you describe sounds like fuel starvation.
Based on that premise, I would start at the tank and assure that there is nothing in the system of hoses that could cause this issue.
  1. The pickup tube. Some boat builders install a screen to filter any debris in the tank. Lift the tank dip hose, and clean/remove the screen so that fuel can flow freely from tank into hose
  2. Next hose from tank to first filter. Assure hose is clear of any debris. Diesel fuel can degrade. A sticky gelatin like substance (Asphaltines) can form and get sucked up into the hose. Clogs can happen along a hose or at connections like the entry into a fuel filter. Check to assure no debris is in the line
  3. Fuel check valves. Some off engine fuel filters have a small check installed. It stops fuel from draining back into the tank. @Stu Jackson has discovered and written about it here on SBO. Assure it is not stuck closed
  4. You installed clean filters. I had this issue. Here is an image of a dirty filter that caused my engine to stop.
  5. Then there is the filter on the engine
  6. Finally the fuel lines from the engine filter to the injectors
With the fuel lines clear try the engine again and report back.
This can be a messy job but is the best way to be sure that fuel can flow to your engine and go Vrroom.
Likes: FastOlson
Aug 1, 2023
7
I disconnected the fuel supply and return lines at the engine (supply line just upstream of the lift pump) and put a couple short hoses into a fresh diesel can and the motor worked fine. So next I disconnected and inspected every component of the fuel system from the uptake tube in the tank all the way to the end of the supply hose. Fuel in tank clean and not degraded (as far as I could tell). I replaced a ball-type check valve at the tank that I thought could be sticking, but this didn’t help. Finally I removed and took apart the entire fuel/water separator manifold and discovered some gunk in there (this version has no check valves in it) but probably not enough to cause the problem. Anyway, the manifold is probably as old as the boat (over 40 years) so I decided to order a new one in case air intrusion, etc is contributing to the problem at this point. If this doesn’t do it I’m pretty sure I need a priest or something.
