Mud dauber wasp idea
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
These things are real pests! They build their mud hives everywhere. They even plugged up the weep hole at the base of my mast and caused rainwater to get into the cabin. I cleaned out the mast base thru an inspection cover and cleared the drains. I'm looking for ideas to keep them out.
One is to stuff flotation in the halyard holes where they get in. I'd have to remove it when we sail. My other thought is to put a no pest strip inside the base. Do you think this would help get rid of them?
5,591
Pearson 37 Lusby MD
I'm told they don't like dryer sheets (like Bounce).
Likes: Rich Stidger
Mar 26, 2011
4,050
Corsair F-24 MK I Deale, MD
Spitballing. I wonder if there is something you could apply to the halyard when the sail is up, which would pull into the mast when the sail is down. Some say citronella. Confined inside the mast, it should be pretty strong. If you have a spare halyard that would be handy. I do not believe it affects polyester or polyethylene.
Likes: Dalliance
Jul 7, 2004
8,542
I have an extra halyard. It might be worth a try. Especially for the top of the mast.
Sep 26, 2008
812
Hunter 340 0 Wickford, RI
I use moth balls (not the flake style) in small bags I make from cheesecloth. A few in each bag, hang one in the area the wasps are making nests, the smell will repel them for a few weeks at a time as the moth balls slowly melt away. I place a small bag inside my Life Sling bag, they seem to like it in there.
Mar 26, 2011
4,050
The top of the mast was the part that go me thinking.
I assume there is a slight updraft (chimney) when the mast gets in the sun, so maybe the bottom is all you need.
Likes: kloudie1
This actually works! I do the same thing. Mothballs also repel spiders, and the chemical (naphthalene) also kills mold spores. So keeping an open Tupperware in your boat when you’re not using, it will keep mildew and mold from growing in your boat. But the stuff does leave a pungent odor that takes an hour or so to blow out of the boat so… Always in search of a better solution
Apr 25, 2024
828
Fortunately, we do not need to worry about this. We do not have insects or spiders of any variety and never have, on any of our boats. Not even mosquitos. Occasionally a bee will come out, when we are on the water, and fly along with us for a while, but they don't stay.
But, as for mothballs ... in addition to the unpleasant smell, they are really quite toxic, even to humans. I don't know if you can still buy the old naphthalene kind but they are really flammable. The newer PDCB kind aren't as flammable, but are still probably carcinogenic. What the actual risks are, when used only when the boat is unattended, I don't know. But, it is worth knowing there might be some risks.
My suggestion would be to identify all places a wasp might enter and install tiny turnstiles which cost a quarter to get through. This will encourage them to go to your neighbor's boat to save money. Wasps are famously ... stingy.
Mar 26, 2011
4,050
My concern is that napthalene is a suspected/probable carcinogen. It's not just a pungent odor. It's more for long terms storage than something you will occupy.
It is true we have but a few insects to disturb our lives. There are yellow jackets in the August/September time frame.
During my cruise leaving Port Browning BC and heading back to the US, I transited between the Islands of Pender and Saturna. On the wind were honey bees. It appeared they were making the journey between the Islands. The wind was blowing 15+. The bees would land in the cockpit. They would orient themselves face to the sun and hunker down out of the wind. After a brief rest they would launch into the wind and be whisked away. This interesting event was repeated 20 plus times over a 50 minute passage. Then they were gone.
May 7, 2012
1,630
Hunter e33 Maple Bay, BC
And when they come out, they come out in full force.
John, I have had very good luck with products from a company called Rescue! I use them at home and boat. Several years ago I hung one at the mast and within a couple of hours I had dozens as in upwards of 50 in the trap. Both neighbours and I were happy.
I do see they also make one for mud dabbers.
TrapStik, Wasp
Yes you need to respect it for sure. But I use it for winter storage in the boat... and hold my breath when I close up the tupperware and open the hatches when I open the boat up in the spring. You need to handle it with care.
If anyone is considering using it, here is the Safety Data Sheet
Mar 26, 2011
4,050
In my case, I sail year round, so there is no such thing. Why would you put the boat "up" in Charleston? Heck, that's why you live in the south! (I might put it up for the summer--too hot)
My neighbor pointed out a Yellow Jacket nest in the Cottonwood tree behind his house. It is the size of a small beach ball. I placed a Rescue Yellow Jacket Trap yesterday. This morning it is nearly full and still attracting more wasps. I set a second trap and will wait till tomorrow in the chill of the morning daybreak to bag and toss the full trap.
Those suckers are nasty. They can multiple sting. They call their friends to help when they attack. :yikes:
Dec 2, 1997
9,011
- - LIttle Rock
Don't forget the holding tank vent....it, along with a gas grill venturi, is a favorite mud dauber "home." The good news is mud daubers are only a problem in the spring...yellow jackets live underground and only come out in late summer and fall and they're aggressive! Meat tenderizer is the best treatment for yellow jacket stings..wet the sting, shake some on the sting and rub it in. I used to keep it a bottle of it with the first aid stuff on my boat...during raft-ups close to shore it stayed in the air going from boat to boat.
--Peggie
