Hey everyone,
Took a closer look under the cockpit in the aft-most part of my 1981 Hunter Cherubini 30, and I’ve got a few issues that need addressing:
The rudder stuffing box hose, clamps, and packing material all look like they’re ready for retirement.
The scupper hoses back there are laughably brittle — almost like dryer vent hose. I can crush them between two fingers. Definitely not marine-grade. I want to replace them with proper reinforced hose and new clamps.
I know the steps: loosen clamps, slip off the stuffing box hose, repack the gland, and install new clamps and hose — but my problem is access.
From what I can tell, everything has to be reached by squeezing into a small access door behind the aft berth. I barely fit through it. On the other side, the fuel tank blocks most of the cockpit locker, so reaching the rudder stock from there is tough too. I can lay down in there, but it’s not ideal.
Two main questions:
1. Has anyone figured out a better access route to this aft compartment on a Cherubini 30?
2. How do I drop the rudder post slightly so I can slip off the old stuffing box hose and install the new one?
Appreciate any insight — I’m fully comfortable with the mechanical part of this job. Just trying to avoid a full-on contortionist act or yanking the fuel tank if I don’t have to.
Thanks in advance.
Two main questions:
Thanks in advance.
