Universal M-18 fuel return line part identification
May 11, 2013
5
Catalina 27 6590 Des Moines WA
The Universal M-18 diesel engine in my 1989 Catalina 27 wing keel has a leak in the metal line connecting the two injectors and taking unused fuel back to the tank. Universal was sold to Westerbeke, which lists a "fuel leak-off" line as part no. 302923 which appears to be the correct part. Here is the link: LINE - Westerbeke
At one time Universal (and also Kubota, which makes the block) used a rubber tube between nipples on the injectors, which is available, but the injectors in this motor do not have the nipples and the injectors do not need to be replaced.
If anyone can confirm that this is the right part or suggest something else it would be much appreciated!
Aug 11, 2011
1,020
O'day 30 313 Georgetown MD
Where in the metal line, is the leak? Is it at the fitting or at what point in the line. In other words, is there enough metal hose to do a temporary fix by sliding a fuel rated rubber hose over the two metal lines? You'll need to cut out a section from the point of the leak, about 1/2" then slide the rubber over and maybe use a thin piece of SS wire and twist it over each end.There is very little pressure in that line.
(I'm finding it a little hard to explain the process of repair so please excuse me if it sounds confusing. I attach a drawing of what I'm trying to describe)
10,255
Another option is to find exactly where the leak is, remove the "leak-off" manifold and take it to a machine shop that can silver solder the leak.. If it is a corrosion pinhole, ya probably going to have another one or two that are going to be a problem soon.. In that casae, you can cut the manifold apart at the ends of the connectors and leave a "nipple" on each end.. Then as 2 Dzus says get a piece of small fuel line and use spring clamps (like on a lawnmower) to hold the ends of the hose in place..
There is no pressure on that line since it dumps back into the fuel tank and the flow rate is tiny..
(Yes, my wife calls me a CAE* because I fix most things even if she wants a new one) * Cheap Ashed Engineer
May 11, 2013
5
Good suggestion! Unfortunately the break is right at the injector so there would not be enough to attach a hose to. It looks like the whole assembly will have to be removed and either repaired or replaced. Oh well.
May 11, 2013
5
Sounds like you may have removed the manifold before (same part on M25). Does it just lift off after the upmost nuts on the injectors are removed? Any gaskets needed?
Aug 11, 2011
1,020
If I remember correctly (mine is a 5416, which has two cylinders), each injector needs a crush washer to go in first before screwing in the injector (make sure you get the old one out). As mine has flexible fuel lines, the two banjo fittings (one with single nipple and one with double nipple) had copper washer seal for one side. Refer to picture below, please.
Jul 23, 2009
931
I'm not sure every diesel repair shop would be familiar with that system but the one I use is. It's used on lots of old tractors. The shop I use was eager to help. Make a few phone calls. You might find they have exactly what you need. Or have it silver soldered.
May 11, 2013
5
Just
If I remember correctly (mine is a 5416, which has two cylinders), each injector needs a crush washer to go in first before screwing in the injector (make sure you get the old one out). As mine has flexible fuel lines, the two banjo fittings (one with single nipple and one with double nipple) had copper washer seal for one side. Refer to picture below, please.View attachment 233206
I was out of town and just now catching up on messages. Appreciate the reply very much - the diagram answers my question. Westerbeke located a manifold and I have a mechanic who can put it in next week.
May 11, 2013
5
A mechanic recommended silver soldering, but Westerbeke located the part and the mechanic will install it. This engine is a jewel - 3,000 plus hours and runs like new!
Glad you located the part. At 3000 hours, the engine is just getting broken in.
In Seattle, I use Seattle Injector. https://www.seattleinjector.com/contact-us
They have or know where to get diesel injector parts. They are priced for trucks, not boats, so I have saved money. They are also quick to resolve issues.
