Hauling out Tuesday and could use some advice.
I’ve got two thru-hulls in my boat’s bilge area:
One is a depth transducer that still works fine.
The other is a speed transducer/paddlewheel that barely works anymore.
Both thru-hulls have slow leaks, and the backing plates underneath are rotted and soft. I’m going on the hard, so I’ll have time to fix it properly.
I’m debating whether to:
Just re-bed the same depth transducer after fixing the hull and backing plate.
Upgrade to newer transducers for depth or speed.
Glass over the holes completely if I decide I don’t really need these thru-hulls anymore.
I don’t think I need new seacocks in those spots for anything else, and I’d prefer fewer holes in the boat if possible.
My questions:
Would you keep the old depth transducer if it’s still working, or replace it while the boat’s hauled out?
Is a thru-hull speed transducer worth keeping, or should I rely on GPS?
If I remove them, would you glass over the holes completely, or leave them as spare seacocks just in case?
Any tips for repairing the hull/core if it’s wet around those holes?
Trying to keep the boat simple and avoid future leaks. Appreciate any thoughts or experiences. Thanks!
My questions:
