Hi all,
It was a bit of a slow day at work today, so I was thinking about emergency tillers (as one does). I know where mine is, in case I need it, but have never actually tried fitting it in position. I was looking at my reference pictures and realized...it may not be as straightforward as I have always casually assumed.
The PO installed a linear drive system. In doing this he modified the floor boards, cutting out the normal floor in order to make room for the rudder position sensor. He then added a fiberglass "stepstool" that sits over this area on the edges of the cut out floor. The cut out removed the normal port/cover that one would open in order to drop the emergency tiller post into position.
In looking at the rudder cable system underneath I realize that I'm not sure where the post would mount. My gut feeling is that I would need to remove the rudder position sensor and the block of wood upon which is mounted (the black device that says Raytheon) to expose the hole into which the tiller would drop. But I'd rather not go tearing things apart just to test if I'm actually incorrect on this...
Does anyone have knowledge or a picture of your non-modified setup on a mid-90's mid-sized Hunter? (We have a 1996 Hunter 376, but I'm sure most of the 30-40 foot boats of that era have a similar configuration).
Pardon the messiness of this area. When I took the picture I was pulling things apart to clean, but that came later in the order of operations.
Thanks!
Doug
Thanks!
Doug
