The Rusty Compression Post Problem
Oct 9, 2013
37
Hunter 30 Lusby, MD
I have finally decided that it is time to deal with the rusty compression post on our 82 Hunter 30.
I don't want it to crumble and collapses creating an even bigger problem.
I know several of you have already successfully dealt with this problem so I am looking for advice from your experience.
Nov 8, 2007
1,590
Looks like a tough problem to me!
My ideas include:
- Use a hydraulic jack (or two) at the side(s) of the post to take the load while you work on the post.
- Hammering a custom cut steel or aluminum bar on the side could perform a similar backup function.
- Then, I would simply clean off the rust on the pipe. While it may look scary, rust increases the volume of the iron in the post, and the existing post may well be able to do the job after you clean it off.
- Applying a rust resisting coating would finish the job.
- If I were still not confident in the pipe, I would consider welding helper bars on either side of the pipe.
I would defer to others who have replaced the pipe for advice on that solution. If that was my plan, it would involve pulling the mast to relieve the compression stress on the hull from the stays as well as hydraulic jacks to maintain the position during the replacement.
Oct 9, 2013
37
Hunter 30 Lusby, MD
My ideas include:
Thanks, yes relieving and supporting the load during the work is part of my still developing plan for this project.
Dec 28, 2015
1,907
I posted about my replacement about 5 years ago. It isn't hard, you just have to plan it out and prep for a mess if you need to grind out glass. I had too. The biggest challenge was bringing everything you need to the boat. Second biggest is coming up with space to jack up the bulkhead ceiling wile keeping space to work. I used 4x4s and bottle jacks (make sure you remember to loosen your rigging). I would not do the work with the compression post in place. Remove it and inspect. I ended up adding a second compression post to mine due to the mast step not being centered on the compression post. I added a carbon fiber plate to the ceiling that spanned the whole area of the mast step, re-installed the original compression post then added another infront of it with a gap for the bathroom door (sliding) to pass between them. The combination now supports the whole area of the step. I replaced bilge step, which was original I-Beam, with composite material and have been very happy with it, no issues and it isn't going to rot again.
37
Hunter 30 Lusby, MD
Thanks, I found your old post and reviewed it as I was researching this project. Not looking forward to all the time laying on the floor with my arms in the bilge and the tool I need in my home 30 minutes from the boat. My 82H30 looks like a different setup. I don't have the I-beam and there is 2" square tubing that runs under the floor like a rib and has another 2" welded mast support that runs down to the top of the keel. Yes, there will be cutting and grinding and shop vacuuming fun to remove the rusty 2" steel tube and the mess that it is sitting on. Looking at replacing it with G10.
