Hunter 45CC Fischer Panda I1 & I2 output good but no power to boat's Line 2 (air conditioners)
Aug 18, 2014
4
HUNTER 45CC ANNAPOLIS, MD
How does the Generator switch on the Hunter panel work...does it activate relays or transfer switch...if so where are they located?
Thanks
Bill aboard Balance, Jacksonville, FL
Jun 14, 2007
185
Hunter 45cc Florida
What is the year of your 45cc. If around 2005 they did have relays to switch the circuits. Located behind cushion by the table. Circuit breaker panel for your 115 volt circuits
Jun 14, 2007
185
Hunter 45cc Florida
Do you have the owners manual. It has the circuit diagram for the AC switching system. You have to remove the cover on the box to access the relays
