Does anybody have a speed table for the Hunter 23.5
Feb 22, 2025
17
Hunter 23.5 Navarre
Does anybody have average speeds for the Hunter 23.5 at close-haul, close reach, beam reach, broad reach, running versus light winds, moderate winds and strong winds (I assume light winds are <10 kts, moderate 10-20 kts and strong >20 kts) ? I've looked all over the internet for this data. If there is no speed table, what has been your experience? I just bought a 1993 H23.5, replaced the mast and plan to go sailing this Friday.
You asked about speeds and the truth is that it is not hard to drive these boats at 6 kts even in breezes of only 6 kts. You are not going to push her above 6.5 without some extreme effort.
The 23.5, 26 and 260 are all water ballast boats with a large main that is the primary driver of the boat. These boats sail best when sailed FLAT. It is a very different feel than a traditional keel boat. So you need to reef early to keep them on their feet if you want to make good speed.
At 10 Kts, you will already have a reef in place. I always leave the dock with one reef in and shake it out if needed. If you don't have a second reef point, you will be sailing on jib only at 15 kts and maybe even have a few turns on the roller furller.
If you are going to regularly encounter 20 kts winds, you will def. want a second set of reef points in your main so you can keep your balance.
Spending some time getting your reefing system dialed in so you can reef and shake-out with ease will make your experience much better. I added three additional deck organizers and rope clutches to my H26 so that I could run ALL lines (including reef lines) to the cockpit.
Sep 30, 2016
383
Island Packet IP 44 Ventura, CA
OP, you are looking for the Polar Diagram for your boat. I never found one. It takes a lot of testing to make a accurate polar diagram, and I dont think there's one out there. Rgranger's post is pretty much same as my experience w a 23.5- They will do 5-6 kts easily. No one is competitively racing or going on long voyages with these boats, so I dont think there has ever been a real need to produce an accurate polar diagram.
May 27, 2024
15
Hunter 240 7026 Maryport, Cumbria
Many thanks for that, I think the most I've ever had out of her was 7kn , I usually bumble along at 4 or 5 which suits me fine.
Likes: FWBpilot
Jun 12, 2021
297
Hunter 240 Aqualand Marina, Lake Lanier
Six knots is about max in a H240. If I replace my main it will have two reef points.
Likes: FWBpilot
