2012 373 Beneteau LCD measures voltage/water/fuel.
Jun 23, 2025
4
Beneteau 373 St Thomas
Hello all. I own a 373 Beneteau and need to replace the LCD measures voltage, water and fuel. Any recommendations will be sincerely appreciated. The display is 1.5” x 2.5”.
It looks like you can still get the original panel from Beneteau, part 156278 for $518. We had ours replaced about 7 years ago after a nearby lightning strike.
Likes: marcham
HI David, any chance you have link to the Beneteau site where the part is listed?
It’s through https://spareparts.beneteauusa.com
You’ll need a Beneteau dealer to set up credentials to log into the site. Once you add the item to your cart that dealer will fulfill the order. You might also be able to just talk to the dealer about ordering the part directly without going through the site.
Jun 17, 2022
551
Hunter 380 Comox BC
Call your nearest dealer. They will get you access to the website. You order via your dealer when you make the online purchase on the Beneteau website....
Likes: BigEasy
