Hi - have had trouble on the 2004 Hunter 41 mainsail furling for a while - just had a new sail made, not really much better. Two years ago we had the mast pulled and a new halyard swivel installed, didn’t help much either. Embarrassed to say I personally had not put the sail on or off since then - but with the new sail came across this (picture). Seems like the hook for the sail was installed upside down and someone put in a pad eye on the foil to shackle the sail to as a fix. Is it possible in any way this is contributing the to difficulties, including uneven and difficult furling ? Certaly you can’t really use the hook easily - the sail falls off unless you twist the heck out of the loop and over tension the halyard - I’ve just shackled to the pad eye.
