Hooking up an Older atomic4 to chartplotter
Aug 17, 2013
994
Pearson P30 202 Ottawa/Gatineau
Hello everyone, I am looking for info from anyone who has connected their older atomic 4 engine to their Raymarine chartplotter.
I know I need an analog to mnea 2k converter, but my question is are they all the same.
Quick backstory.
I don’t have a tach on my panel and no room for one, my instrument panel is out of reach from the helm, I would love to be able to look at the info when motoring without having to leave the helm.
I would love to be able to add a fuel tank sensor as well, it would take the guess work out of the equation.
My Pearson P30’s gas gauge is a very long wooden spoon that I insert in the gas filler neck which is located in the middle of my cockpit floor just ahead of the helm, great fun, but really not easy to check (foam carpets to remove to access)
If I could get temp sensor and oil pressure, that would be great as well.
already asked the question on the Moyer forum last year and not much traffic over there so no answer.
thank you in advance
Here is one resource that may provide a solution.
Jun 1, 2004
8,181
Excellent resource. If I understand correctly, you simply connect the existing analog sensors to the conversion device, (from the instrument panel or from the sensor itself?), which is converted to a digital display on chartplotter/multi display. Is it really that simple.... and inexpensive? cool :cool:
3,233
C&C 30 Mk1 Winnipeg
Yes. :biggrin:;)
Sorta. You need to calibrate the device so it knows how to convert the signals.
That said...
My nerd side says, cool. But after looking at how I want to install an nmea bridge on our current boat, I don't really see the point of spending time and money on it engine monitoring unless you have a bigger boat.
There are cheap and small sub $100 digital displays that connect to analog sensors.
For most of us, the engine controls and gauges are right there. All people need to do is turn their head.
If they aren't that close to see, I would still prefer separate gauges, and relocate them if needed... because I am not a fan of having a single point of failure. (The nmea bridge)
3,233
C&C 30 Mk1 Winnipeg
Fwiw, when I was looking into adding engine monitoring, I found this post on the panbo site (the place for boat electronic nerds to geek out).
It discusses the process on a trawler but the basic idea applies. The RS11 seems like a great choice.
Likes: fred1diver
Oct 10, 2009
1,042
Catalina 27 3657 Lake Monroe
Is this just about adding a tach to existing gauges? Without seeing the cluster, I'd venture that there is room for oil pressure, temp, ammeter, which I think would have been standard and is what I had in my 1978 Catalina. I rewired the engine, rebuilt the panel with new gauges and swapped the ammeter for a voltmeter and there was enough room for a fourth gauge, too.
Likes: Leeward Rail
Aug 17, 2013
994
Pearson 30 Instrument Panel Redesign - Moyer Marine Atomic 4 Community - Home of the Afourians.jpeg
this is what I have on mine at the moment, this is not mine, I borrowed a pic from the net, on mine there is the master key over the temp gauge.
The PO put it there.
Now I figure that either I connect the gauges to my plotter or move the panel closer to the helm, if I do this it would make it easier to operate when solo, at the moment I need to leave the helm to shut off the engine, not very practical in an emergency situation, or if and when the motor stalls (I think I fixed that issue)
the only one I wouldn’t move is the choke.
what do you guys think?
Mar 20, 2015
3,233
C&C 30 Mk1 Winnipeg
Yes it is a location problem, especially when considering that the gauges are exactly where people’s legs are when sitting :banghead:
That's literally every boat that has a tiller and many that have wheels. Including our C&C.We're not staring at the gauges when the engine is running and we are under way, so it's not a problem.
We have audible alarms for oil pressure and engine temperature, to alert us to problems.
The boat didn't have an RPM gauge, but I added one. It isn't mandatory, but it's nice when doing engine tuneups. I upgraded all the switches in the panel, to toggle style.
At some point I will get a new panel plate made of laser cut and engraved stainless sheet just for cosmetics and because I know someone with the laser cutter.
Likes: fred1diver
Jan 7, 2011
5,507
Oday 322 East Chicago, IN
Same problem for me on my O’Day 322.
i was going to relocate the engine panel up high on the coaming, but it would have required a very big hole and I want too comfortable with that.
So, I am moving select instruments to the coaming where I can see them…
So far, engine hour meter and fuel gauge.
I would like to get the tach moved (or a smaller one added) to the coaming area.
