Looking for advice dropping the windlass gearbox and motor for a gear-oil change.
2004 Catalina 34 MK2, Maxwell VC-500 windlass.
I’ve followed all owner’s manual instructions, but the darn thing won’t drop down.
Removed topside parts and the four windlass mounting bolts. I can now jiggle and twist the below deck gear, but something is preventing it from dropping down. Tried gently tapping the shaft with rubber mallet; no luck. Tried using liquid wrench in case mounting sleeve is corroded; no luck. Scoured YouTube; no luck.
Has anyone else encountered this problem?
Thanks in advance
Thanks in advance
