Mast leak. I am looking for a diagram of how mast to compression post is designed on Hunter Passage 42cc1997
Apr 18, 2021
5
Hunter Passage 42 Olverson’s nnk VA
Mast is leaking around deck step area. The boat was recently worked on. This involved removing and replacing the mast.
so something was overlooked in my mind.
I am far removed from yard at this time so they are no help. If I could understand how the mast is stepped I have a much better chance Of stopping the leak.
This boat has Zspar system which has gotten me through two hurricanes. No complaints here..Raymarine not so happy with.
Dec 25, 2000
6,055
Feb 10, 2004
4,236
Hunter 40.5 Warwick, RI
Had a similar problem when we purchased our boat in 2002. PO did a crappy repair job so fixed it once and for all. Wrote an article about it here: Hunter 42 Owner Modifications and Upgrades
Also, the mast step plate has a weep hole that needs periodic cleaning. Wrote an article about it here: Hunter 42 Owner Modifications and Upgrades
IMHO, making a drip loop in the wire bundle is a critical part of keeping water out of the cabin. But that must be done when the mast is stepped.
