Seacock on holding tank vent hose?
Feb 10, 2004
4,253
Hunter 40.5 Warwick, RI
I have a fellow boater who has a 2005(?) Hunter 44 and he has a seacock on the holding tank vent hose. He never closes it. He is replacing the vent hose with a larger size and he asked me about the seacock.
I have never seen or heard of a seacock on a holding tank vent.
Does anyone else have this seacock? Opinions on keeping it?
JBP-PA
Apr 29, 2022
832
Jeanneau Tonic 23 Erie, PA
Is the vent low enough that it might be below water level when heeled over?
Mar 26, 2011
4,050
Corsair F-24 MK I Deale, MD
The obvious problem is that pressure build up could blow the tank. Eww.
  • Temperature change.
  • Flushing the toilet. Worse if the tank is full, but this creates pressure even if it is not.
  • Biological generation of gases (primarily CO2 and H2S). This is the one that would scare me silly if it were closed for more than an hour. I guess he never heard of landfill gas. I've operated digestors, and they bubble. I'm pretty sure that could blow the tank in a few days.
I would move the vent to where I could remove the valve. If not possible, then he should lock the valve open with a cable tie to avoid a catastrophe. The worst that will happen if it goes under a wave is that he will fill his tank. No biggy.
Feb 10, 2004
4,253
No. The vent is over half-way up the topsides. And the valve is never closed. We just can't figure out why the valve is present, or if it was installed by Hunter or the PO.
Likes: JBP-PA
MFD
Jun 23, 2016
305
Hunter 41DS Pacific NW USA
Different boat, Hunter 41DS.
In mine, there is a seacock on the hot water tank TPV discharge line that goes out up near the gunnel.
Which is a curiosity if it’s own. My understanding is that hot water blow out needs to go overboard, not the bilge, if the boat has plumbing for a shore water connection. Meanwhile the seacock in both cases makes me think of explosions…
Meanwhile is your friend sure it’s the holding tank and not the hot water tank?
Dec 2, 1997
9,011
- - LIttle Rock
First I've ever heard of a seacock on a holding tank vent line--leaving me wondering if that's what it is. My guess: It could be a PO's hair brained idea of the best way to prevent filling up the holding tank with seawater when heeled far enough to put the vent thru-hull under water and staying on that tack long enough for that to happen. I wonder if he confused a line coming off an overboard discharge pump with the vent line and thought he was putting the "missing" seacock on it.
--Peggie
Apr 25, 2024
828
Like others, I am confused about the purpose. I can sort of see if the vent was on the deck and you wanted to prevent deck runoff (rain, seawater, etc.) from adding to the holding tank. I could see this as being (marginally) beneficial if the boat is left unattended for a long time and the vent was positioned where it readily swallowed this runoff ... I guess. Not how I would solve that problem, if I had it, but just speculating ... I can sort of see why a person might do that.
But, more to the point - if that's what it actually is and there is no confusion, I cannot advise keeping it. But, not knowing exactly why it is there, I can't advise getting rid of it. I guess I would just say that, if they keep it, they should know why, and not just keep it because it was already there.
JBP-PA
Apr 29, 2022
832
Here is what Practical Sailor had to say. I don't know what they mean by "add security". I couldn't find the 1994 article mentioned.
"Holding tank vents should be plastic, not metal. There are no metals that deal well with the corrosive gases being vented; all metals will either discolor or pit in this application.
A simple through-hull design is best as it allows you to backflush the vent using a garden water hose. Follow the American Boat and Yacht Council (ABYC) standards for installing a through-hull above the waterline (section H-27), and be sure to include a beefy backing plate. Adding a seacock (PS test, Sept. 1, 1994) to the setup isn’t necessary, but it would add security."
