Hi there:
I recently saw when I started my engine that there was no water being expelled from the transom port. I assume I have a cooling issue and have checked the raw water pump and removed the heat exchanger. It seems that all the blades of the impeller are there and the heat exchanger has some, but not a ton of debris inside (I have the 3'' x 13'' model). Any suggestions? I'm about to install a strainer, could use some advice on which model and also installation. I'm hoping it's not the exhaust elbow!
Thank you for your help.
