Hello again
Apr 25, 2024
532
Fuji 32 Bellingham
I doubt anyone will know what you are talking about. Maybe a little explanation? I did find an app by that name by simply searching for it, but have no way of knowing if this is the app to which you are referring.
Mar 21, 2022
133
Bristol Corsair Tampa
Chart symbols & abbreviations there was apparently an app servuced by "SAFE SKIPPER".
It seems that isn't acá anymore. So, im trying to find out if theres another way to obtain
this info in the form of study cards, cheat sheet, ect in order to study, memorize them in order to be quick on my charts handling, ect
PaulK
Dec 1, 2009
1,408
Sabre 402 Southport, CT
If you look up NOAA US Chart # 1 you will find the charts and symbols. it should be easy to make study cards from them yourself. Research shows that moving your fingers to draw or take notes on a subject improves retention and helps learners achieve better results.
May 12, 2025
29
Macgregor 22 Silverton OR
The chart or map that you are using will require a list of any symbols used on it. If it doesn't have that it's probably fake. Except for Nigerian treasure maps
