Several years ago, I had a leak in the anchor locker, and the drips somehow migrated to where the soft hull liner met the V-berth platform. This platform (the place where the cushions sit) is/was made of plywood with a brown layer laminated on both sides (linoleum?), and the leak caused the plywood to completely delaminate.
So: I"m replacing the whole platform with some 1/2" red oak plywood, which I will coat with 2 layers of epoxy to waterproof it. My question is this: should I re-use the 4 old hatch covers vs. using the plywood that I cut out of the holes as the new hatch covers? To explain: the old hatch covers have a flange on all edges, so they actually sit 1/2 on top of the platform, maybe 1/4" proud. The new wood covers would be cut-outs, so I'd have to use a plywood strip glued/screwed along the joint underneath to keep the covers from falling through. My only worry is whether this strip will be strong enough to hold the weight of a person. I'd actually prefer to use the new wood covers, since it would look better and the entire platform would be flush, but it's got to hold the weight.
