Good Day,
I have a 1990 Hunter Legend 35.5 and have owned it since 2012. I have never replaced the packing in the stuffing box and there doesn't seem to be an issue (there is no leaking when the shaft is not turning and when the shaft is turning there is the required 1-2 drops every minute or so). I still have some threads left on the locking nut where I can tighten it a bit more if required; however, I want to be proactive as apparently the packing should last only 5-7 years and I just found this out.
Every year when the boat first goes in the water, it leaks and then after about 15 minutes it stops as I guess the packing is expanding when the water reaches it. I am really gun-shy in doing this, and have read a lot on the procedure and viewed a lot of videos; however, I can't find my exact setup anywhere. The attached photo shows my stuffing box. As you can see, it has a nylon locking nut and a nylon receptacle. I un-did the locking nut and slid it as far back towards the transmission as possible, which only leaves about 1" clearance to remove the old packing and install new packing. I bought a packing removal tool (attached) and when I used it, it hooked onto a nylon washer that was inside the black tubing. I'm assuming that this is a compression washer which the locking nut uses to evenly compress the packing. I stopped at this point because I'm not sure if the packing rings are immediately behind this washer. As well, I'm concerned about how to get the new packing rings back inside as a screwdriver would not be able to be used to angle it properly to push them back in.
Does anyone have a similar setup and have they replaced the packing rings where you could give me some guidance?
