The galley foot pump in our 1984 Newport 30 MkIII appears to have been installed before the top and bottom silverware drawer teak faceplate was installed onto the fiberglass bulkhead below the sink. The pump sits inside below the bottom shelf and the center horizontal 1x1 piece that separates the upper and lower drawers is in the way of doing anything. It appears the only way to remove and replace the foot pump is to cut that horizontal wood piece, do the installation then glue that piece back. There is no way to access it from the back (unless you tear out the shelf box back piece) or side (unless you cut out some of the fiberglass bulkhead corner at the bottom companion way step) or top (if you went to all the trouble to remove the sink, you wouldn't be able to reach the pump unless someone dangled you upside down!). Has anyone with the same situation replaced their pump yet? Is this how you did it?
